JonnWhite Posted September 17, 2016 Share Posted September 17, 2016 hello, Dont know if anyone can help got a 64 plate fiesta and the vents are smelling of rotten eggs. It happens if the air con is on or off and i've tested by leaving air con off for a week and on for a week and still there both trials. The only thing that concerns me is that my dad noticed a very loud rumble from the exhaust, it's the ecoboost model and i thought it was just the working of the car. However it could not be? Car's booked in for wednesday. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
Blatto Posted September 17, 2016 Share Posted September 17, 2016 The bad egg smell is probably Hydrogen Sulphide (H2S). That's a product of the Catalytic convertor. It's normal for them to produce certain amounts of H2S but they can produce more if your engine is running lean. Also try using a low Sulphur fuel if you aren't already, see if that reduces the smell., Quote Link to comment Share on other sites More sharing options...
Ticktock Posted September 18, 2016 Share Posted September 18, 2016 You shouldn't be able to smell anything as all the gasses will be filtered through the exhaust. The only time you will smell something is if there is something wrong with the exhaust, so the loud rumble you mention above may be a hole in the exhaust leaking gasses. I'd get it checked out before it makes you sick. 1 Quote Link to comment Share on other sites More sharing options...
jbell Posted September 19, 2016 Share Posted September 19, 2016 Could be bacteria in the air con system Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted September 19, 2016 Share Posted September 19, 2016 32 minutes ago, jbell said: Could be bacteria in the air con system Changing out the filter and hitting the system with koala farts (eucalyptus spray) should sort out any bacteria. Sounds like a hole in the exhaust somewhere though. Quote Link to comment Share on other sites More sharing options...
JonnWhite Posted December 1, 2016 Author Share Posted December 1, 2016 I forgot i posted! It turned out to be the washer bottle. The water went bad and stunk. Ford cleared out for free :D 1 Quote Link to comment Share on other sites More sharing options...
