Guest Posted September 21, 2016 Share Posted September 21, 2016 Hi all, looking at fitting an exhaust tip on the fez, nothing huge, just something aesthetic really. So i noticed the exhaust is curved so i presume I would need to cut that down before clamping on a tip, also the rear splitter already has a gap which looks big enough for an exhaust, if not, any idea how id trim that down to leave enough room for the exhaust tip as I don't want the heat melting it. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 22, 2016 Share Posted September 22, 2016 bump Quote Link to comment Share on other sites More sharing options...
Joss max Posted September 22, 2016 Share Posted September 22, 2016 No need to cut the original curved tail pipe as there are off set exhaust tips available on T'internetz As an example to give you an Idea https://www.amazon.co.uk/gp/product/B016W2NNXU/ref=pd_vtph_263_bs_t_1?ie=UTF8&psc=1&refRID=DWN4E61PK595QS4Q5VNQ You might find this worth a read http://www.ebay.co.uk/gds/Your-Guide-to-Buying-Exhaust-Tips-/10000000177404901/g.html Quote Link to comment Share on other sites More sharing options...
Guest Posted September 23, 2016 Share Posted September 23, 2016 16 hours ago, Joss max said: No need to cut the original curved tail pipe as there are off set exhaust tips available on T'internetz As an example to give you an Idea https://www.amazon.co.uk/gp/product/B016W2NNXU/ref=pd_vtph_263_bs_t_1?ie=UTF8&psc=1&refRID=DWN4E61PK595QS4Q5VNQ You might find this worth a read http://www.ebay.co.uk/gds/Your-Guide-to-Buying-Exhaust-Tips-/10000000177404901/g.html Thanks buddy. The other issue I have is when i look at the exhaust then my bumper, there is a gap but the exhaust sits really high and i reckon if i put a tip on it will sit squint, hard to explain, maybe someone with a fiesta will know what i mean Quote Link to comment Share on other sites More sharing options...
Guest Posted September 23, 2016 Share Posted September 23, 2016 If you look at the below image, a normal curved tip wouldnt work unless i got another bit of pipe and curved is slightly to angle it right inline with the gap... Quote Link to comment Share on other sites More sharing options...
Joss max Posted September 24, 2016 Share Posted September 24, 2016 That is quite an offset isn't it Fraser. It might possibly need some extra pipe welded on to it to get it to line up. To be honest it might be better and more cost effective to buy a complete back box inc tailpipe you want. Quote Link to comment Share on other sites More sharing options...
