Pg75 Posted September 24, 2016 Share Posted September 24, 2016 Why does my ford fiesta 07 plate 60000 miles make road noise Quote Link to comment Share on other sites More sharing options...
jmurray01 Posted September 24, 2016 Share Posted September 24, 2016 Posting this in the right section, and giving some more information might help!! The general chat area is clearly marked "Talk about anything NOT Ford related". 1 Quote Link to comment Share on other sites More sharing options...
Benji. Posted September 24, 2016 Share Posted September 24, 2016 Also, more specifics might help. 'Road noise' is fairly vague, seeing as every vehicle will make noise when driving... Quote Link to comment Share on other sites More sharing options...
Russ Posted September 24, 2016 Share Posted September 24, 2016 1 hour ago, Pg75 said: Why does my ford fiesta 07 plate 60000 miles make road noise How worn are your tyres, I've found that as you get 'near the limit' of wear the road noise tends to increase. Second what Benjamin said. Quote Link to comment Share on other sites More sharing options...
GaryPL Posted September 24, 2016 Share Posted September 24, 2016 5 hours ago, Pg75 said: Why does my ford fiesta 07 plate 60000 miles make road noise Physics. 5 Quote Link to comment Share on other sites More sharing options...
Bobr Posted September 25, 2016 Share Posted September 25, 2016 I've never had a car yet that didn't make road noise. It can be alleviated to some extent by your choice of tyres. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted September 26, 2016 Share Posted September 26, 2016 Tyre choice tyre wear, road surface type, its all to do with friction at the end of the day. Each tyre generates an amount of friction, more friction means more volume as noise is waste product along with heat. Sent from my D6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
jace1969 Posted September 27, 2016 Share Posted September 27, 2016 This was the big thing with me when i had my fiesta was road noise,focus is a lot better but fiesta being smaller and not a lot of padding don't help. The tyres i have tried 3 lots and a bit better but still there,you just get use of it well i have,my old 09 corsa was very quiet but i would rather have my car with no tyres than that car. Quote Link to comment Share on other sites More sharing options...
Joss max Posted September 27, 2016 Share Posted September 27, 2016 On 24/09/2016 at 4:58 PM, Pg75 said: Why does my ford fiesta 07 plate 60000 miles make road noise Have you not gone into setting> Road noise > Tyre noise> Cancel That should sort it 2 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted September 27, 2016 Share Posted September 27, 2016 2 minutes ago, Joss max said: Have you not gone into setting> Road noise > Tyre noise> Cancel That should sort it I wish that option was on the Focus dash!! The real answer is because Ford are too tight to fit enough sound deadening. It's so noticeable between even the cheap German stuff and Fords. 1 Quote Link to comment Share on other sites More sharing options...
FordFezza Posted September 27, 2016 Share Posted September 27, 2016 30 minutes ago, Joss max said: Have you not gone into setting> Road noise > Tyre noise> Cancel That should sort it I can confirm this works 100% 1 Quote Link to comment Share on other sites More sharing options...
jace1969 Posted September 28, 2016 Share Posted September 28, 2016 On 27/09/2016 at 6:58 PM, Joss max said: Have you not gone into setting> Road noise > Tyre noise> Cancel That should sort it Lol you are spot on,is this only on the Facelift as mine is 2011 but i do have a radio what helps. 1 Quote Link to comment Share on other sites More sharing options...
