rocket_111 Posted September 25, 2016 Share Posted September 25, 2016 Hi, I'm picking up a new titanium x in a couple of weeks time and would like to hard wire a dash cam in, I can see the fuses used for the MK2, MK 2.5 & MK3 but is the fuse for the MK3.5 the F85? or is there a better one to use? What are peoples thoughts on the OBD11 port adaptor to power the dash cam, looks so much easier to do.. Cheers Quote Link to comment Share on other sites More sharing options...
alexp999 Posted September 25, 2016 Share Posted September 25, 2016 I used 87 which is the one for heated steering on mine. 85 should work fine too. OBD is always live so wouldn't switch off with ignition. It's really easy with a fuse tap. 2 Quote Link to comment Share on other sites More sharing options...
rocket_111 Posted September 25, 2016 Author Share Posted September 25, 2016 Thanks Alex, I didn't go for the heated wheel option, so I'll fuse tap into 85 then..Cheers 1 Quote Link to comment Share on other sites More sharing options...
