markjb777 Posted September 27, 2016 Share Posted September 27, 2016 I had what I thought was a dead battery so charged it for a couple of days, refitted & nothing apart from the rev counter / speedo spinning around then going back to zero. I purchased a new battery & absolutely nothing. is there a main fuse or relay causing no power getting through ? or is it the starter ? any idea's ? Car is a 2007 Mondeo TDCI 2.2 diesel estate cheers Mark ... Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted September 27, 2016 Share Posted September 27, 2016 Probable bad earth somewhere - start with the battery connection to the body. Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted September 27, 2016 Share Posted September 27, 2016 8 hours ago, markjb777 said: I purchased a new battery & absolutely nothing. is there a main fuse or relay causing no power getting through ? or is it the starter ? any idea's ? It could be a lot of things, from earth connections & fuses to the immobiliser. You should go through checking various electrical functions from sidelights & headlights to all the indicator lamps on the instrument cluster. It could just be earth, like Mark (above) says, including the earth to the engine. Then there are relays & fuses related to the ignition key, and a starter relay. If it was the starter motor, there will usually be a click from the motor as the solenoid pulls in, or tries to pull-in. If you don't have the manual, this may help: http://www.autogenius.info/ford-mondeo-mk4-fuse-box-diagram/ Quote Link to comment Share on other sites More sharing options...
