jochapl Posted September 27, 2016 Share Posted September 27, 2016 Hello all, i'm having a little bit of trouble with my mk3 mondeo 2.0 tdci. First of all, it came up with the usual P0251 code which then I have replaced the injectors that made it run better. It then got bad again so I attempted to change the solenoid valve on the injection pump. Ever since i did that the car would not want to start for some unknown reason but there appears to be fuel making its way to the injectors as I cracked them open and plenty of fuel was escaping. The codes I have been given are known as P2291 Injector pressure too low - Engine cranking and P2623 injector control pressure regulator open circuit. Please could anyone help me as im stunned from what this car throws up when one thing goes wrong. Many thanks Quote Link to comment Share on other sites More sharing options...
