high rpm prior to vehicle coming to a halt
4 replies to this topic
#1 mike alexandre
mike alexandre
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Ford Model: escort mk3 1997
Posted 15 June 2008 - 06:54 PM
car is a 97 escort 1.6 16 valve zetec petrol fuel injection.
engine starts normaly cold and hot. revs settle at 1200.
having driven off for a short distance - depressing clutch shortly prior to stopping -eng revs move up to 1500 untill wheels stop-this without foot on throttle pedal
In daytime temps of 25/27 deg c above condition is persistant-in lower outside temps revs reduce to 900 ie normal idle.
Engine has been checked at main dealers-cause of problem not found-please advise.
Have something to contribute?
#2 mike alexandre
mike alexandre
    Newbie
  • New Member
  • Pip
  • 4 posts
Posted 07 July 2008 - 05:14 PM
Any ideas anybody?
#3 vinnyvangough
vinnyvangough
  • 2,325 posts
  • Name: Steve
  • Ford Model: 2003 Focus TDCi, Escort Mk6 RS2000, Mk2
  • Year: 2003
Posted 05 August 2008 - 09:21 PM
I know on the Ford Ka the idle control valve plays up and causes this problem, not sure if its the same on the Escort. Might be worth checking out.
#4 romfordir
romfordir
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: escort 1.8 si
Posted 25 August 2008 - 05:23 PM
hiya
im new to this forum but i was having a read about the escort stuff , being a owner meself and the problem with the high RPMs happens to me , but mine is usually after a motorway or high speed run, when the engine is running at normal on temp gauge , but if i goto work early in morning i can have a fast run and its ok in cold weather , its due to go in for a service in a few weeks time so ill get robbie to have a look , but a guy at work has a GTi which had the same problem he said his was the lambada sensor , once robbie's sorted it ill post what mine was
cheers
Graham
#5 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,550 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 26 August 2008 - 09:33 PM
this is most likley the idle speed controlle valve, take it off and clean it with carb cleaner no sharp instruments) 9/10 times it will cure the fault. the following might help
http://www.kivisite.hu/ford_pdf/
Not what you're looking for?
