ScottlGH Posted October 7, 2016 Share Posted October 7, 2016 Anyone else experiencing this on their windows or know how to fix it? Quote Link to comment Share on other sites More sharing options...
lukespoor Posted October 7, 2016 Share Posted October 7, 2016 Problem? It looks like you've damaged/scrapped the trim on it. Quote Link to comment Share on other sites More sharing options...
ScottlGH Posted October 7, 2016 Author Share Posted October 7, 2016 Its just happened over the course of a few weeks, its on both doors but the drivers side; which is the more effected area has started to split. Quote Link to comment Share on other sites More sharing options...
E5GDM Posted October 7, 2016 Share Posted October 7, 2016 Has it ever had 'wind deflectors' on? Quote Link to comment Share on other sites More sharing options...
ScottlGH Posted October 7, 2016 Author Share Posted October 7, 2016 It has but I didn't think they would have caused this as they go inside the window frame?😕 I tried to put it back under the seal but its like a plastic material and wouldn't stay, also I didn't want cause it to split it more. Not sure whether to heat it up and try shape it back in? Quote Link to comment Share on other sites More sharing options...
metty Posted October 26, 2016 Share Posted October 26, 2016 Just want to let you know that FMC will usually cover the cost of replacing trim items as a good will gesture if the item is just outside of warranty, but will also usually assist with any repairs if your vehicle is below 45 mths, your local dealer will usually do this for you without you having to contact FMC. It is based on loyalty so if you use your dealer for sales and service then there is no reason why they should not cover the full cost of this for you. However if you do not get a satisfactory result from the dealer you can contact Ford customer relationship center on 0845 841 1111 they will contact the dealer to discuss this with them on your behalf and try to get this sorted for you. Quote Link to comment Share on other sites More sharing options...
