DJGee Posted October 18, 2016 Share Posted October 18, 2016 Hi all, First post looking for a bit of help I have a 2002 1.3 LX Mk6 and my oil light keeps coming on once the car has warmed up. Only happens when the revs drop below 1,000rpm then it flickers then comes on solid. I've just replaced the oil pressure switch and done a oil + filter change but still persists. I'm still getting oil to the top of the engine I checked before and wasn't a lot at the top then check when I got to work and the top was coated. Would suggest that I've still got oil pressure to get oil to the top. Anyone suggest what to check next? EDIT: Sorry should mention I did check oil level before doing the oil + filter change and it was just under max. Quote Link to comment Share on other sites More sharing options...
DieselPig Posted October 18, 2016 Share Posted October 18, 2016 Depending on how many miles this beauty has done either the oil pump is worn or the big ends. Quote Link to comment Share on other sites More sharing options...
DJGee Posted October 19, 2016 Author Share Posted October 19, 2016 11 hours ago, DieselPig said: Depending on how many miles this beauty has done either the oil pump is worn or the big ends. Car has done just under 127,000 miles, I've got no knocking noises from the engine. Quote Link to comment Share on other sites More sharing options...
DieselPig Posted October 20, 2016 Share Posted October 20, 2016 OK. Stationary, with the engine hot, put in neutral and rev the engine, hold it at 2500 rpm. If you hear a knock throttle off, the bottom end is worn. If no knock the oil pump is worn assuming you have the correct grade of oil in it. Quote Link to comment Share on other sites More sharing options...
