MusicalChris Posted October 25, 2016 Share Posted October 25, 2016 Hi Guys, have heard you can do a Master reset to reset eveything? the instructions on the Ford website do not seem to add up, does anyone know if this is possible and if so how to do this I have a 2011 Zetec-S Thanks again Chris Quote Link to comment Share on other sites More sharing options...
Joss max Posted October 25, 2016 Share Posted October 25, 2016 Hello and welcome Chris Are you asking about master reset of sync ? Can you post the link to the website you where working from? Quote Link to comment Share on other sites More sharing options...
MusicalChris Posted October 25, 2016 Author Share Posted October 25, 2016 Hi Joss, this is the ford link that comes up: https://owner.ford.com/how-tos/sync-technology/sync/settings/how-to-perform-a-master-reset.html Select year and model and instructions don't seem to follow what menus i have Thanks again Chris Quote Link to comment Share on other sites More sharing options...
alexp999 Posted October 25, 2016 Share Posted October 25, 2016 That's for the US, your 2011 Fiesta will not have Sync. Quote Link to comment Share on other sites More sharing options...
Joss max Posted October 25, 2016 Share Posted October 25, 2016 Ok Chris Assuming your car has sync 1 version. It makes the assumption your phone is currently paired via bluetooth to sync. Just follow the instructions below. Before you start There are a few things you should do before starting step 1: Your vehicle must be in Park and running, not in Accessory mode. Familiarize yourself with the controls in your vehicle. Make a note of any saved Navigation points and other personal data. This process will erase all of your data from SYNC, and will restore SYNC to factory settings. On your phone, choose bluetooth from the Settings menu, then select SYNC and delete it. 48 On the SYNC screen, press the Phone button. The SYNC screen will display either: Connecting No phone paired or connected Press the Arrows or Seek buttons until Return displays on the screen. Press OK. Press the Arrows or Seek buttons until Advanced displays on the screen. Press OK. Press the Arrows or Seek buttons until Master Reset displays on the screen. Press OK. A Confirmation message displays on the screen. Press OK. After completing a master reset you will need to pair your phone to SYNC. Quote Link to comment Share on other sites More sharing options...
MusicalChris Posted October 25, 2016 Author Share Posted October 25, 2016 Hi ok, so it seems that the uk stereos do not have any sort of Master Reset? is that correct Cheers Chris Quote Link to comment Share on other sites More sharing options...
alexp999 Posted October 25, 2016 Share Posted October 25, 2016 If you have Sync it will have an option to master reset, but your car is too old to have been built with it afaik... You can check on the etis website if it was built with it, I thought it was 2012 they added it... Quote Link to comment Share on other sites More sharing options...
