Richard2k84 Posted October 25, 2016 Share Posted October 25, 2016 Hi Just thought I would post this as I have recently had a leak in my coolant system. The leak was on the inside of the car with the pipes going to the heater matrix. I spoke to ford as all that was wrong is a o ring had seen better days and gave up. Apparently Ford do not sell the o ring and I needed to buy a new heater matrix (about £180). Thats a lot of money for a old o ring. So I have found out the size of the o ring needed to fix the issue is 18mm(inside diameter) by 2mm thick. You can search online for them (not sure if I can say were i got them from on this site) for a few quid. Absolute pig of a job as the pipes are up by the clutch pedal, but it can be done at home with a mirror a light. I had it sorted in about a hour, but it took longer to dry the car out as it leaks into the footwell Good luck, and hope this helps Cheers Rich 3 Quote Link to comment Share on other sites More sharing options...
mikeyd1 Posted October 25, 2016 Share Posted October 25, 2016 3 hours ago, Richard2k84 said: Hi Just thought I would post this as I have recently had a leak in my coolant system. The leak was on the inside of the car with the pipes going to the heater matrix. I spoke to ford as all that was wrong is a o ring had seen better days and gave up. Apparently Ford do not sell the o ring and I needed to buy a new heater matrix (about £180). Thats a lot of money for a old o ring. So I have found out the size of the o ring needed to fix the issue is 18mm(inside diameter) by 2mm thick. You can search online for them (not sure if I can say were i got them from on this site) for a few quid. Absolute pig of a job as the pipes are up by the clutch pedal, but it can be done at home with a mirror a light. I had it sorted in about a hour, but it took longer to dry the car out as it leaks into the footwell Good luck, and hope this helps Cheers Rich Im sure ypur post will come in handy for someone. Dealerships seem to think we are made of money Quote Link to comment Share on other sites More sharing options...
