Branchinho Posted October 31, 2016 Share Posted October 31, 2016 I have a 2014 plate Ford Fiesta and have recently changed the headlights from daytime running to the fancier led daytime running lights. All the bulbs seem to be working fine (they light up) but just noticed today when driving in the dark when my dipped beam on one side seems to travel a bit further than the other. So if you imagine one side the light travels 2 car lengths in front (not accurate just easy to explain) where as the other side only reaches one cars length. Is it a simple replacement bulb or is there more to it than that? Or am I missing something else? Thanks Tom Quote Link to comment Share on other sites More sharing options...
Jamie4589 Posted February 3, 2017 Share Posted February 3, 2017 Hi Did you manage to sort the problem ? Also I was looking at upgrading to led daytime running lights, was it a straight swap or did you have to change anything ?Thanks for any replys 1 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted February 4, 2017 Share Posted February 4, 2017 I would imagine it was user error and one of the bulbs was not seated correctly. The LED Bulbs are a direct replacement, just search through some of the online car shops or eBay. If the car is CANbus monitored then you will need to get error free bulbs or an inline relay.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted February 4, 2017 Share Posted February 4, 2017 Would it not just be the beam pattern? One side travels further than the other, as far as I can tell with my own lights the left looks as though it travels further 1 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted February 7, 2017 Share Posted February 7, 2017 I'm not sure the left travels further but it should shine wider if that makes sense, to put light on the curb it flicks up at the left side. Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Branchinho Posted April 22, 2017 Author Share Posted April 22, 2017 Jonro only just seen this but yes it was a straight swap (assuming you haven't already done this) however getting the headlights out is a bit trickey and requires a bit of trial and error.. couple of good guides out there though... good luck! Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted April 22, 2017 Share Posted April 22, 2017 Jonro only just seen this but yes it was a straight swap (assuming you haven't already done this) however getting the headlights out is a bit trickey and requires a bit of trial and error.. couple of good guides out there though... good luck! It wasn't me asking about changing them bud, it was the guy above my first comment. How did you get on with your problem, did you fix the different beam lengths? Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Branchinho Posted April 22, 2017 Author Share Posted April 22, 2017 Oh yeah.. haha oops? sorry about that! And yeah just wasn't sitting in properly (the headlight) it looked it but having adjusted the bottom clip it sits on everything is good now! And yes one beam does seem wider than the other I think it was the left one? Can't remember but apparently it's supposed too... 🤔 Im currently debating weather I should get rally style mud flaps... 🤔🤔🤔 Quote Link to comment Share on other sites More sharing options...
