Mk4 Lumpy Under Acceleration
6 replies to this topic
#1 A2D2
A2D2
    Newbie
  • Pip
  • 8 posts
  • Ford Model: Fiesta Mk.4
Posted 17 June 2008 - 11:43 PM
Hey you lot, I'm new to the forums, hopefully I can provide info as well as deal out the problems :)
I purchased a '99 Mk4 Fiesta about 8 months ago and gradually the lower end of the gears, when I need to accelerate mid to hard it feels as if the engine momentarilly cuts out for a few seconds then around the torque band it sorts itself out.
replaced the spark plugs a month or two ago and the problem ironed itself out for a while, but it has returned again! I bought some Redex for injected engines thinking its maybe a problem with the injector bank?
Question is, is it my driving style? Or am I missing something important?
Any questions just fire away.
Thanks in advance, will probably edit to add things I've forgot!
#2 Steve
Steve
    Administrator
  • Admin
  • 4,822 posts
  • Ford Model: Kugy
Posted 18 June 2008 - 04:54 PM
have you checked out the HT leads?
#3 A2D2
A2D2
    Newbie
  • Pip
  • 8 posts
Posted 18 June 2008 - 05:04 PM
HT leads arent bad, could be an idea to replace them and see if it clears up.
#4 Steve
Steve
    Administrator
  • Admin
  • 4,822 posts
  • Ford Model: Kugy
Posted 18 June 2008 - 10:17 PM
thinking about it if one went then it would be rough as you would have a cylinder down... so try the distributor cap, rotar arm inside.
I am taking a guess though.
Also check the lead from the coil to the distributor.
#5 A2D2
A2D2
    Newbie
  • Pip
  • 8 posts
Posted 18 June 2008 - 10:24 PM
Thanks for the info will 'ave a look this weekend!
#6 duncstar
duncstar
    Newbie
  • Pip
  • 5 posts
  • Ford Model: fiesta
Posted 19 June 2008 - 11:33 AM
If its a zetec it will have a coil pack not distributor.
#7 A2D2
A2D2
    Newbie
  • Pip
  • 8 posts
Posted 22 June 2008 - 03:50 PM
Report: Had a quick once over of the car with my car and all was fine until we started the car up. Dad was under de bonnet and said when a gave it some throttle there was a sort of swooshin, air escaping from a pipe noise. He thinks that might be the porblem for the lack of power under acceleration.
Needs looked at!
