scoot600 Posted November 7, 2016 Share Posted November 7, 2016 I have a service oil warning light coming on whenever I start the car. I have tried the clutch and brake pedal solution for removing it but to no avail. Does this warning signify some sort of problem or is it just a timing thing for an oil change? The model is a 1.6 TDCI Focus Sport Quote Link to comment Share on other sites More sharing options...
andypsp Posted November 7, 2016 Share Posted November 7, 2016 did you have the door closed when you tried to do the reset for oil Quote Link to comment Share on other sites More sharing options...
scoot600 Posted November 7, 2016 Author Share Posted November 7, 2016 13 minutes ago, andypsp said: did you have the door closed when you tried to do the reset for oil yes all doors shut Quote Link to comment Share on other sites More sharing options...
iantt Posted November 7, 2016 Share Posted November 7, 2016 for oil reset its brake and accelerater down then ign on, if that doesnt switch light off, then theres a fault somewhere that needs investigation Quote Link to comment Share on other sites More sharing options...
scoot600 Posted November 7, 2016 Author Share Posted November 7, 2016 7 minutes ago, iantt said: for oil reset its brake and accelerater down then ign on, if that doesnt switch light off, then theres a fault somewhere that needs investigation Will try that, I may have been doing it wrong by pressing clutch and brake Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted November 8, 2016 Share Posted November 8, 2016 Have you actually checked the oil level? That light is the oil pressure light which means there is either a lack of oil or the pressure it too low. Also when was the oil last changed? You have a MK2.5 with a 1.6TDCi engine. This needs to be done every 6000 miles to maintain a working engine. Quote Link to comment Share on other sites More sharing options...
scoot600 Posted November 8, 2016 Author Share Posted November 8, 2016 oil Warning now reset using gas and brake pedal 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted November 8, 2016 Share Posted November 8, 2016 so was it due an oil change , or wasnt it reset last time it was changed? Quote Link to comment Share on other sites More sharing options...
keith walker Posted January 20, 2021 Share Posted January 20, 2021 I have the same problem. I have just serviced the car ( ford focus 1.6 TDI 2013 model ) changed oil, oil filter and air filter then cleared service light by brake and accelerater depression but after an hour or two the oil service light comes on again?. Quote Link to comment Share on other sites More sharing options...
Yousif Iskander Posted March 11, 2021 Share Posted March 11, 2021 I experienced the same problem as Keith Walker. So serviced car (focus 2011 2.0TD), cleared service light, and 3 days later light back on, and stayed back on even after clearing multiple times. Any solutions yet? Quote Link to comment Share on other sites More sharing options...
andypsp Posted March 12, 2021 Share Posted March 12, 2021 Have you put enough oil in and is it the red light on the dash you have comeing on Quote Link to comment Share on other sites More sharing options...
