Jaiimez Posted November 10, 2016 Share Posted November 10, 2016 Hey so i'm going to be removing the damage brake caliper bolts on my Focus this weekend, i'm just curious what is the size of them so I can get replacement new ones before I start. (If anyones wondering the bolt heads are rounded off hence the need for replacing). It's the bolt at the top and bottom of the caliper that hold it in place. Quote Link to comment Share on other sites More sharing options...
williamweb Posted November 10, 2016 Share Posted November 10, 2016 If it's a MK1 the hex head bolt is 13mm buddy. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
mjt Posted November 11, 2016 Share Posted November 11, 2016 12 hours ago, Jaiimez said: what is the size of them so I can get replacement new ones before I start. Best advice would be to get them from your friendly Ford dealer . They'll be able to identify them on their parts catalogue. I wouldn't just buy bolts from a shop as you need to be sure they're the right grade of material. It's not worth risking it for something as safety-critical as brakes. Quote Link to comment Share on other sites More sharing options...
Jaiimez Posted December 9, 2016 Author Share Posted December 9, 2016 On 11/11/2016 at 10:10 AM, mjt said: Best advice would be to get them from your friendly Ford dealer . They'll be able to identify them on their parts catalogue. I wouldn't just buy bolts from a shop as you need to be sure they're the right grade of material. It's not worth risking it for something as safety-critical as brakes. I did thanks, went into our local ford parts wasn't as bad as I expected was only 98p a boit. Quote Link to comment Share on other sites More sharing options...
TangoDaz Posted December 9, 2016 Share Posted December 9, 2016 Yes best getting the proper bolts as they sometimes have a patch lock on them to prevent them coming undone Quote Link to comment Share on other sites More sharing options...
