gilles27
Flashing light on dashboard
Hi all, I have a problem with my Focus (2002 TDCi) which I would appreciate some help with. Sometimes, after driving for 5 or 10 minutes, the glow plug indicator light on the dashboard starts flashing and the engine suffers a reduction in power. If I restart the car, the problem goes away.
According the manual, "if the light flashes when driving, it indicates a malfunction". I'd like to know if this means a problem with the glow plugs (i.e. one or more need replacing) or something else altogether. My understanding of the glow plugs is that they are only used when the car is started, after that they are not used. This makes me think that something else is wrong.
I'd appreciate any suggestions, especially from others who have had the same experience.
Thanks,
Ross
Thanks,
Ross
MY mate has a mercedes c class had a similar problem
we thought like you the glow plugs only work before starting
On the mercedes they thay have 2 stages one for starting then when running they come on again untill the car warms up (to do with the emiisions) they keep the manifold warm
his car had a fault on the control unit so they were not comming on after the car had started same sort of warning light
we could not understand why the glow plugs came on the car started OK then the warning light came on after it was running
may be the Focus has similar system some one may know more than me
Thanks,
Ross
Could be a few things. If it has a fuel filter with only 2 pipes and an electrical sensor it is most likely the fuel filter needs changing. But if they flash and the enging stops it is something more serious. One point here though, before you take it to get the diagnostic code read, make sure the fault warning light is on. Normally the fault has to occur twice before it will lock in an error code!
the glow plug light covers many issus...it is an indicator that you have a problem.Idealy it should go to a dealer with the correct IDS equipment for accurate diagnosis.YYou ned to go to a dealership at some point to cler the fault codes and havethe light put out.
Thanks,
Ross
Had the Same problem but had read somewhere that iy can be the injectors losing code... Rang my fuel Injection Specialist who recoded the system that was 25k ago been fine ever since now at 150k
Hi, new to the forum. Have spent many hours trying to find an answer but no joy so I'm hoping someone here can help?
Jumped in on this topic as I can't seem to start a new one yet.
Anyways, message i light flashed red on my 2009 Focus 1.6TDCi Zetec for about a minute whilst driving. There were no messages at the time and none in the message memory when I checked later. It may have occurred shortly after I restarted too quickly from a stall. No other warning lights. Just a glitch or a warning to take seriously? Thanks.
I have a flashing red light on the dashboard on the left side of the radio of my ford fiesta, didn't even notice there was a light there before. Recently added oil and had the battery charged as I left my lights on yesterday, any know what this is, or if there is any connection to the battery being recharged. Car running fine but this light is not going off.
