Bryan271 Posted November 27, 2016 Share Posted November 27, 2016 Hi all new to this forum... I have a 16reg Focus ST3 Nav and when I go to enter postcode on sat Nav it will not let me enter the last to letters of the postcode... Anyone any ideas before I go to local ford garage to see what's wrong.....Thanks in advance.... Quote Link to comment Share on other sites More sharing options...
Joss max Posted November 27, 2016 Share Posted November 27, 2016 Hello and welcome Bryan As far as I am aware sync 2 does not allow you to enter full UK postcodes. Watch video and note it takes you to general area of post code, Close enough but no plans to update sync 2 to accept full postcode. 1 Quote Link to comment Share on other sites More sharing options...
Bryan271 Posted November 27, 2016 Author Share Posted November 27, 2016 1 hour ago, Joss max said: Hello and welcome Bryan As far as I am aware sync 2 does not allow you to enter full UK postcodes. Watch video and note it takes you to general area of post code, Close enough but no plans to update sync 2 to accept full postcode. This video allows you to enter full postcode but on mine when I go to enter last 2 letters of postcode screen does not light up letters.....Would have thought in a 25k car (Nav edition) you would be allowed to enter full postcode..Will talk to local ford dealer and see if this is right.... Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 27, 2016 Share Posted November 27, 2016 You can enter full postcodes but need to enter a space between the two parts. Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
Bryan271 Posted November 27, 2016 Author Share Posted November 27, 2016 21 minutes ago, Stoney871 said: You can enter full postcodes but need to enter a space between the two parts. Sent from my SM-G930F Have left space unsure what's wrong.... Quote Link to comment Share on other sites More sharing options...
Linds Posted November 28, 2016 Share Posted November 28, 2016 Could you have got the postcode wrong? Quote Link to comment Share on other sites More sharing options...
alexp999 Posted November 28, 2016 Share Posted November 28, 2016 What version SD card have you got? Quote Link to comment Share on other sites More sharing options...
Bryan271 Posted November 30, 2016 Author Share Posted November 30, 2016 Called into a ford garage and explained my problem...Was told that's the way they are....Can this be right?? Total balls if having a half sat Nav in my option... Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 30, 2016 Share Posted November 30, 2016 I can enter a full postcode no problems.Are you sure you're leaving a space?If not then the system assumes you're applying a 2 number first part ( ie, AB33 1AA) if you do that then the numbers will stay selected until the first part is filled.Remember that the system will only show letters or numbers that it knows from the SD card database, if it's a new postcode issued after the database was created then it won't recognise/display it.Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
Bryan271 Posted December 2, 2016 Author Share Posted December 2, 2016 On 30 November 2016 at 10:46 PM, Stoney871 said: I can enter a full postcode no problems. Are you sure you're leaving a space? If not then the system assumes you're applying a 2 number first part ( ie, AB33 1AA) if you do that then the numbers will stay selected until the first part is filled. Remember that the system will only show letters or numbers that it knows from the SD card database, if it's a new postcode issued after the database was created then it won't recognise/display it. Sent from my SM-G930F Tried the above and found out will let me enter a mainland uk postcode in full but not a N.Ireland one(where I live) so pretty much useless...... ie BT93 6GF won't let me enter the G or F.... Will call into local ford dealer in morning to see is there a fix.... Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 2, 2016 Share Posted December 2, 2016 I've driven mine in NI (Belfast etc) when visiting the in-laws and had no problems.Strange.Sent from my SM-G930F Quote Link to comment Share on other sites More sharing options...
TitXlover Posted December 2, 2016 Share Posted December 2, 2016 Mine is ok, it's a bit tricky to use, keep forgetting how it works as I only use it occasionally. There was a problem with the f3 SD card and post codes. If you haven't got this SD, not sure what the problem might be? There are a few You tube videos how to use the sat nav. Quote Link to comment Share on other sites More sharing options...
Howard 2 Posted November 10, 2018 Share Posted November 10, 2018 I find that I can enter the post code leaving the gap with the space button but I cannot always enter the house number, the digital keypad does not allow it, mine is an F5 card, the local dealership has tried this on other Sync 2 models in their stock and all seem to have the same problem, this issue is on going with Ford. Quote Link to comment Share on other sites More sharing options...
nathanphillips Posted November 10, 2018 Share Posted November 10, 2018 .Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
