Son of Nod Posted December 2, 2016 Share Posted December 2, 2016 Ok. Our 56 plate focus had it mot last Friday. It failed.. Bushes both sides front Blue Wipers Cost 240. Paid it and drove car home Monday only to be greeted by whistling sound. Phoned garage up and they said they'll collect and look. Today the car finally picked up only to find that the brake pads and discs need changing. Hold on....they passed MOT and failed straight away and will set back 140.... I am thinking that during the changing of bushes something happened causing damage to discs and pads. I am fuming. Any advise. Quote Link to comment Share on other sites More sharing options...
Joss max Posted December 2, 2016 Share Posted December 2, 2016 35 minutes ago, Son of Nod said: Hold on....they passed MOT and failed straight away and will set back 140.... If the pads and discs passed on the day of the test, then a day or too later they say they need changing. Then something is wrong. You would at least expect the garage to give you an advisory on your MOT cert that although they passed, they are close to needing renewal. Second opinion would be wise 1 Quote Link to comment Share on other sites More sharing options...
Son of Nod Posted December 4, 2016 Author Share Posted December 4, 2016 Update. So car went in for pads and discs. I called garage and questioned him. Said don't take wheels off for mot and if passed pressure test then ok. So I asked how he knew it was the pads and discs? He sailed that's what's causing the noise. So.... When collecting car I was told discs ok but changed pads. The brake discs where now ok and didn't need changing. Drove car home only to hear metal scrapping noise. Returned car to garage. Mystery... Bloke looked and said it was his fault as bent something back to change bushes... Hmmmm..... Conning little so and so. Quote Link to comment Share on other sites More sharing options...
iantt Posted December 4, 2016 Share Posted December 4, 2016 noise would have been the metal shield around the bottom ball touching the disc, idiot obviously bent it fitting lower arm. you have been conned if the pads didnt need changing. 2 Quote Link to comment Share on other sites More sharing options...
biff55 Posted December 4, 2016 Share Posted December 4, 2016 i'd avoid this garage in future , nothing they have done so far fills me with confidence that should continue working on your car......... and i would have asked to see the old pads , easy way to catch them out if theyre full of sh#t and solid reason to refuse paying.... 1 Quote Link to comment Share on other sites More sharing options...
Son of Nod Posted December 4, 2016 Author Share Posted December 4, 2016 No way of knowing if right brake pads I think. He can whistle now. Quote Link to comment Share on other sites More sharing options...
wilto Posted December 5, 2016 Share Posted December 5, 2016 My car failed it's mot this year on discs and pads, when inspect by my mate ( mechanic) they were totally f***ed, nearly down to the metal on inboard side, mot tester even showed me from under the car, so yes they can see them without taking the wheel off. Quote Link to comment Share on other sites More sharing options...
