[Jacky.C] Posted December 9, 2016 Share Posted December 9, 2016 Hi guys, I'm new to this forum, not sure this post is in the right section or not, but I would be appreciated if anyone could help. I found a rectangular foam sticking out from the front towards the engine under the bonnet, anyone has any idea where is it suppose to be? Quote Link to comment Share on other sites More sharing options...
alexp999 Posted December 9, 2016 Share Posted December 9, 2016 Moved to focus section for you. Do you have a picture? Quote Link to comment Share on other sites More sharing options...
[Jacky.C] Posted December 12, 2016 Author Share Posted December 12, 2016 This is the foam that I was talking about, does anyone have the same problem? Quote Link to comment Share on other sites More sharing options...
[Jacky.C] Posted December 12, 2016 Author Share Posted December 12, 2016 Apart from the foam, I just noticed there are other problems as well 1) the tap seems to be falling off, should I re-tape it? 2) there is some orange colour sludge/sticky oil on the parts, is that due to leakage or just normal dirt? Would be be appreciated if anyone could help! :) Quote Link to comment Share on other sites More sharing options...
mjt Posted December 12, 2016 Share Posted December 12, 2016 Picture 1 : No idea where that's come from. I've had a look under the bonnet of our Ecoboost and can't see anything in that area. Picture 2 : I'd just trim off the surplus tape. The rest still looks ok. Picture 3 : That's just grease that's been applied to the bonnet lock mechanism. Quote Link to comment Share on other sites More sharing options...
[Jacky.C] Posted December 12, 2016 Author Share Posted December 12, 2016 Thanks for your help, Mike! Quote Link to comment Share on other sites More sharing options...
JW1982 Posted December 12, 2016 Share Posted December 12, 2016 The piece of foam belongs on top of the radiator / fan housing. The piece of foam has a self adhesive backing. Unfortunately as a result of heat the piece of foam often comes loose from the radiator / fan housing. A simple solution for this problem is re-installing the piece of foam at the correct location using a contact adhesive. 1 Quote Link to comment Share on other sites More sharing options...
[Jacky.C] Posted December 12, 2016 Author Share Posted December 12, 2016 Thank you JW! Would you mind showing me the location? Quote Link to comment Share on other sites More sharing options...
