as400 Posted December 26, 2016 Share Posted December 26, 2016 When I go over a bump the front end of my car sounds like a bag of spanners. Just had a major service at Halfords and nothing was picked up, not sure if they even test drive it. Are they all like that Sir?...or could there be something loose? How noisy is yours when you go over a speed bump etc? Car has done 77K and is standard 2.0tdci Ghia as far as I know Quote Link to comment Share on other sites More sharing options...
artscot79 Posted December 26, 2016 Share Posted December 26, 2016 no it shouldn't sound like that most likely a broken spring but hard to say you really need to get under it to see..i wouldn't trust Halfords to change a bulb never mind service a car 1 Quote Link to comment Share on other sites More sharing options...
williamweb Posted December 26, 2016 Share Posted December 26, 2016 Push the front corners down and hear if you can isolate the noise.Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
Tomson Posted December 26, 2016 Share Posted December 26, 2016 Broken spring will be my bet. 1 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted December 28, 2016 Share Posted December 28, 2016 or you weren't paying attention driving home and ran over a beggar with a cup full of loose change...park in a quiet place if there's no muffled groans it may be too late if there is leave a pork pie and some juice out theyll eventually come out lol 2 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted December 28, 2016 Share Posted December 28, 2016 1+ on the broken spring, same happened to me (was broken right down in the cup so couldn't see anything wrong until the car was on a ramp and the wheel unloaded) Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 28, 2016 Share Posted December 28, 2016 broken springs on the front are very easy to spot, you might notice the spring isn't sitting at the stop or you might see it has a sharp edge rather than a clean cut. If the spring is on then all the usual suspension parts need looking over for wear or damage. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 28, 2016 Share Posted December 28, 2016 You could also try the shoe test, Basically if theres no fat chicks sitting in the car and you fit more shoe in on one side compared to the other side then the spring is definitely broken #DirtNastyLow 1 Quote Link to comment Share on other sites More sharing options...
