colinr Posted December 5, 2009 Share Posted December 5, 2009 Hi I am having starting problems with my 1800 escort diesel van 51 plate Been told it may be the injection pump not sure yet so I thought I will get a second hand pump if this turns out to be the problem. But I have now been told that if I fit a second hand pump from another van it will not work as they are coded to the engine. Can any one tell me if this is correct if so is there a way round this. Thanks Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted December 5, 2009 Share Posted December 5, 2009 Depends if it is mechanical injection or electronic...not sure on that age, is it a turbo?? You sure it needs a pump...what else has been tried?? Piggy :) Quote Link to comment Share on other sites More sharing options...
colinr Posted December 5, 2009 Author Share Posted December 5, 2009 Depends if it is mechanical injection or electronic...not sure on that age, is it a turbo??You sure it needs a pump...what else has been tried?? Piggy :) Hi. I have put on new starter motor, glow plugs, battery, primer pump, oil, fuel and air filters. Its fine when running but the longer I leave it the Harder it is to start. (non turbo) Quote Link to comment Share on other sites More sharing options...
rustneversleeps Posted December 6, 2009 Share Posted December 6, 2009 Hi. I have put on new starter motor, glow plugs, battery, primer pump,Oil, fuel and air filters. Its fine when running but the longer I leave it the Harder it is to start. (non turbo) Really feel for you colinr,having the same problem with mine on a Yplate,but must say that I,ll bin mine before replacing all that gear you have.Thank christ Ive got a back up. Quote Link to comment Share on other sites More sharing options...
colmac1 Posted December 13, 2009 Share Posted December 13, 2009 Hi I am having starting problems with my 1800 escort diesel van 51 plateBeen told it may be the injection pump not sure yet so I thought I will get a second hand pump if this turns out to be the problem. But I have now been told that if I fit a second hand pump from another van it will not work as they are coded to the engine. Can any one tell me if this is correct if so is there a way round this. Thanks hi there i had the same prob with my 75 escort van and i took 1 off my donner van 55 it still works but if ur low if in diesel it takes more effort to start. before u start it pump it from the diesel pump till its hard then it will fire up thats what i do every morning. Quote Link to comment Share on other sites More sharing options...
rustneversleeps Posted December 13, 2009 Share Posted December 13, 2009 hi there i had the same prob with my 75 escort van and i took 1 off my donner van 55 it still works but if ur low if in diesel it takes more effort to start. before u start it pump it from the diesel pump till its hard then it will fire up thats what i do every morning. Colmac1 what do u mean pump it till its hard and from where (under the bonnet?) cheers and thanks.................ers51 Quote Link to comment Share on other sites More sharing options...
