pocusfocus Posted December 29, 2016 Share Posted December 29, 2016 sted just now · Guys got a problem with my mk1 tdci focus it revs slow! .. but when it is in gears and i drive it dosent go over 3.7 revs its like its lacking power.. turbo sounds ok and no noise what can it be?? It will go 4k revs when in 3rd 4th 5th... no codes on dashcheck it does smoke on low revs not alot. Quote Link to comment Share on other sites More sharing options...
Dennis the meance Posted December 29, 2016 Share Posted December 29, 2016 When was oil air fuel filters last changed ? Quote Link to comment Share on other sites More sharing options...
cgriff40 Posted December 29, 2016 Share Posted December 29, 2016 (edited) I had the same problem with my mk2 , it turned out to be the turbo pressure solenoid that was clogged. I took off the old one cleaned it out but the filters inside had perished beyond repair, so I bought one from eBay and its runs just fine now . just as a suggestion but if your mk 1 has one of these try replacing that. good luck! Edited December 29, 2016 by cgriff40 spelling mistake! Quote Link to comment Share on other sites More sharing options...
ForTim Posted December 29, 2016 Share Posted December 29, 2016 3 hours ago, cgriff40 said: I had the same problem with my mk2 , it turned out to be the turbo pressure solenoid that was clogged. I took off the old one cleaned it out but the filters inside had perished beyond repair, so I bought one from ebay and its runs just fine now . just as a suggestion but if your mk 1 has one of these try replacing that. good luck! Where exactly is that turbo pressure solenoid? Something I found: http://forscan.org/forum/viewtopic.php?f=6&t=880 I had this (unexpected) problem with (vacuum?) hose, probably not related, but just an idea what can go wrong. Quote Link to comment Share on other sites More sharing options...
pocusfocus Posted December 29, 2016 Author Share Posted December 29, 2016 10 hours ago, Dennis the meance said: When was oil air fuel filters last changed ? 7 months ago i did a full service Quote Link to comment Share on other sites More sharing options...
pocusfocus Posted December 29, 2016 Author Share Posted December 29, 2016 5 hours ago, cgriff40 said: I had the same problem with my mk2 , it turned out to be the turbo pressure solenoid that was clogged. I took off the old one cleaned it out but the filters inside had perished beyond repair, so I bought one from ebay and its runs just fine now . just as a suggestion but if your mk 1 has one of these try replacing that. good luck! Yeh i have been searching on the net similar posts have said the same. I do think myself its something to do with turbo ill have a look at that cheers Quote Link to comment Share on other sites More sharing options...
