V6 Misfire..
No replies to this topic
#1 Bowler
  • New Member
  • Pip
  • 1 posts
  • Ford Model: 2003 Mondeo V6 Ghia X
Posted 06 December 2009 - 05:55 PM
I need some help please
I have an 03 V6 Mondeo Ghia X, which seems to have developed a slight misfire.
Before I take it to Ford/my local garage, Id like to try and understand what the fault could be. In short I dont want to be mugged by my local Ford dealer, whilst they chase the fault. If this is simple fault, I can potentially take to my local independent.
Basically the symptoms are it seems to misfire at low revs (1k to 1.5k rpm) sometimes occasionally, sometimes several times, so that the car judders. The fault clears at around 2k rpm and it then misses again around 4,500 sort of once or twice. The judder at low revs is not due to incorrect gear selection. All through the rest of the range it seems to run fine
Apart from that, the car runs fine. Fuel consumption is about the same (+/-30ish) with no other problems
The car has 118k on it and has been regularly serviced.
Im not a techie on these so Ill wont understand the complexities of detailed answers, but has anyone any ideas what this could be
Or, is it just best to take it to Ford and get them to plug in the diagnostics?
Thanks in advance
Have something to contribute?
Not what you're looking for?
