IRONMAN Posted January 10, 2017 Share Posted January 10, 2017 Hi again, Thanks for all the recent help. Would anyone know if the pillar trims can be removed from the 2008 focus for painting. I tried vinyl wrap but it won't stick to the dimpled surface. Cheers 2 Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 10, 2017 Share Posted January 10, 2017 Pull the rubbers away from them and they should clip out you may need to undo the seat belt bolts 3 Quote Link to comment Share on other sites More sharing options...
yunii Posted January 10, 2017 Share Posted January 10, 2017 Hi again, Thanks for all the recent help. Would anyone know if the pillar trims can be removed from the 2008 focus for painting. I tried vinyl wrap but it won't stick to the dimpled surface. Cheers On a mk25 focus you will first need to remove small rectangular plastic trim that says Airbag on it , which will reveal 2 phillips screws .undo these , pull away door rubber. Now you will need to undo torx sealtbelt bolt on bottom of c- pillar. Then slide belt out of trims slot. Btw if 3 door i have black St225 trims to sell . Yunii Sent from my SM-G925F using Tapatalk 5 Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 10, 2017 Share Posted January 10, 2017 remove small rectangular plastic trim that says Airbag on it forgot about them 4 Quote Link to comment Share on other sites More sharing options...
Lenny Posted January 12, 2017 Share Posted January 12, 2017 On Tuesday, January 10, 2017 at 9:43 PM, dezwez said: remove small rectangular plastic trim that says Airbag on it forgot about them Two screws behind it, 2 Quote Link to comment Share on other sites More sharing options...
Lenny Posted January 12, 2017 Share Posted January 12, 2017 Rear quarter roof panels are similar to remove: 2 Quote Link to comment Share on other sites More sharing options...
yunii Posted January 12, 2017 Share Posted January 12, 2017 Thanks Lenny.Now i'd like the 3dr ones Particularly pics more than how to remove.YuniiSent from my SM-G925F using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
IRONMAN Posted January 12, 2017 Author Share Posted January 12, 2017 Thanks again guys for all the reply's and great help. It is the external pillar / window trims, I was looking for. So sorry. 2 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted January 12, 2017 Share Posted January 12, 2017 The external ones are a pig to remove without snapping any of the 3 lugs that hold it in place, it also has factory applied adhesive to make sure it doesn't go anywhere. I'd say if you're going to remove them, be prepared to potentially have to replace them. 1 Quote Link to comment Share on other sites More sharing options...
IRONMAN Posted January 13, 2017 Author Share Posted January 13, 2017 15 hours ago, 1979Damian said: The external ones are a pig to remove without snapping any of the 3 lugs that hold it in place, it also have factory applied adhesive to make sure it doesn't go anyway. I'd say if you're going to remove them, be prepared to potentially have to replace them. Cheers Damian, Will probably give it a miss 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted January 13, 2017 Share Posted January 13, 2017 18 hours ago, IRONMAN said: Thanks again guys for all the reply's and great help. It is the external pillar / window trims, I was looking for. So sorry. 😦.... Quote Link to comment Share on other sites More sharing options...
