shaz4473 Posted June 21, 2008 Share Posted June 21, 2008 HELP!! Today when out I noticed that my battery light has been coming on and off periodically but at the time there was no obvious problem and car was starting and running ok BUT later on in the day when I moved off in 1st gear and took foot off clutch and foot not on accelerator as was moving slowly in traffic that the revs seemed high and when I took car out of gear the revs were pulsing high and back to normal. I revved engine and they went back down to normal but not smoothly. Then idle went back to normal but I noticed that when changing up a gear the revs are going higher at the gear change now and again. Is my car ok to drive?? It is a Feb 2006 Streetka can anybody advise on whether it would be a warranty issue(as if not won't be taking to the local Ford garage!) Any advice gratefully received!!! Quote Link to comment Share on other sites More sharing options...
Steve Posted June 22, 2008 Share Posted June 22, 2008 Hi I would say take the car in to ford. This would be a warranty issue unless it is something to do with changable service parts, ie HT leads, Spark Plugs etc. They will hook the car on to the computer to find any faults Quote Link to comment Share on other sites More sharing options...
shaz4473 Posted June 22, 2008 Author Share Posted June 22, 2008 HiI would say take the car in to ford. This would be a warranty issue unless it is something to do with changable service parts, ie HT leads, Spark Plugs etc. They will hook the car on to the computer to find any faults Thanks for that - on another web forum someone has suggested that it might be the wiring to the alternator. I know a difficult thing to comment on but would you recommend driving the car?? I have not driven it after the problem and have borrowed my mums car for now! I was wary that it would cut out or i would do damage driving it Quote Link to comment Share on other sites More sharing options...
shaz4473 Posted June 29, 2008 Author Share Posted June 29, 2008 UPDATE! Car has been into garage and alternator changed under warranty so hopefully thats the end of that problem! Quote Link to comment Share on other sites More sharing options...
