Car Engine Oil - The Recommended?
MikesFocusZS
 Share
Hi. I usually leave topping my engine oil up with the garage when it goes in for service or M.O.T or other work. But I check regulary.
So I dont really know whats the best oil to buy for my car. I know that my car needs 5W - 30. But when browsing online after putting my car reg into different online checks. It comes back with different names.
For example, Fully Synthetic, Part Synthetic then it will have like A1 or A5.
Are these something that I can only have one of or are they just different grades of oil that will still work for my engine.
I have a feeling that I can only have 5W-30 Fully Synthetic but not sure on the A1 and A5 etc.
I have a Ford Focus Zetec S, 60 plate with the 1.6 Petrol engine.
Any help will be appreciated.
Link to comment
the Halfords oil is fine at £12 for 4ltrs at the mo so get stocked up,
ford oil is always fully synthetic Castrol used to be A1 but they changed it to A5 about a yr ago, it can be picked up around £25-£30 for 4ltrs
so you`ll be safe useing any of them 2
  • Like 1
Link to comment
The link posted for the Shell oil being M2C913-B above should be ok, although the newer Ford spec is M2C913-C which is fully synthectic rather than semi, you can get the genuine Ford formula F for £19 from ebay http://www.ebay.co.uk/itm/New-Genuine-Ford-Fully-Synthetic-5W30-Engine-Oil-5-litres-Formula-F-1502263-/262625193940?hash=item3d25ae6fd4:g:nTYAAOSwwo1XdOrU
Or Opieoils sells some different brands of M2C913-C spec http://www.opieoils.co.uk/search/go?w=913c
Link to comment
51 minutes ago, kingsblue said:
The link posted for the shell oil being M2C913-B above should be ok, although the newer Ford spec is M2C913-C which is fully synthectic rather than semi, you can get the genuine Ford formula F for £19 from ebay http://www.ebay.co.uk/itm/New-Genuine-Ford-Fully-Synthetic-5W30-Engine-Oil-5-litres-Formula-F-1502263-/262625193940?hash=item3d25ae6fd4:g:nTYAAOSwwo1XdOrU
when Castrol changed to A5 there spec for ford now is  M2C913 - D , i think thats why it changed from A1 to A5.
i had Castrol from opie-oils last year on eBay was £20 each and £4.99 pxp great service and quick delivery. mind you they have put there prices up now lol
Link to comment
I also have a 60 plate Zetec S petrol but the 1.8 engine and I have used the Ford formula F that kingsblue mentioned above in both the oil changes I've had since owned, I find its a great price for the manufacturers own oil, can't go wrong.
Link to comment
it`s re-labeled for ford as they don`t make there own oil, but if you look at the eBay link you`ll see the brand is Castrol, not sure what the diffrence is with this eBay item number though  391140611936 as it has a diffrent ford product code
Link to comment
For me personally 5W30 fully synthetic oil is good enough, but with gear oil - specifications are far more important.
Link to comment
On 15/01/2017 at 4:32 PM, ZetecMan1 said:
No problem mate. Still on the same topic.
Cheers for all the answers. Think ill stock up on some.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
