Albert27 Posted January 21, 2017 Share Posted January 21, 2017 Hi guys, Was working on the car today changing the drive belt and while i had the wheel off wanted to look at my brake pads. Looking from the top down view the inner pad seemed a lot thinner on both wheels than the outer. However when i looked from beneath through the little window in the caliper they seemed both the same size so no uneven wear. Am I looking at brake pads from below or have i made a mistake? Or is the view of the pads from the top obstructed by something which is why they're appearing so thin on the inner? Apologies for the very basic questions but this is new to me. Secondly, when should the discs be renewed? What is the minimum thickness or is there anything i should be looking for to signal replacement? It's a focus mk 2.5. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted January 21, 2017 Share Posted January 21, 2017 View from the top can give the illusion they're thinner due to the way light bounces but they could be wearing uneven best way to check would be take them off and measure up or try measure up with them still on, as for when your brakes will need renewing I always say when they start to feel rubbish, after all they're the only thing stopping you. 1 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted January 21, 2017 Author Share Posted January 21, 2017 Attached some pics....... Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted January 21, 2017 Share Posted January 21, 2017 They look okay to me, does the disc have a lip? depending on the size of the lip that would be a good assumption they need replacing. Quote Link to comment Share on other sites More sharing options...
Albert27 Posted January 21, 2017 Author Share Posted January 21, 2017 2 minutes ago, Ryan_Tango said: They look okay to me, does the disc have a lip? depending on the size of the lip that would be a good assumption they need replacing. Thanks Ryan. When you say lip, what exactly do you mean? 9 minutes ago, Ryan_Tango said: View from the top can give the illusion they're thinner due to the way light bounces but they could be wearing uneven best way to check would be take them off and measure up or try measure up with them still on, as for when your brakes will need renewing I always say when they start to feel rubbish, after all they're the only thing stopping you. They feel ok to me....the only thing i have noticed is a grinding type noise when I first apply brakes after the car has been sat a while. Then no noise at all. Is that normal? Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted January 21, 2017 Share Posted January 21, 2017 2 minutes ago, Albert27 said: Thanks Ryan. When you say lip, what exactly do you mean? They feel ok to me....the only thing i have noticed is a grinding type noise when I first apply brakes after the car has been sat a while. Then no noise at all. Is that normal? Sounds like it's just rust scraping off it's normal until it does it all the time. As for the lip 2 Quote Link to comment Share on other sites More sharing options...
iantt Posted January 21, 2017 Share Posted January 21, 2017 look ok to me also. my pads are far thinner than that. lol 1 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted January 21, 2017 Author Share Posted January 21, 2017 5 minutes ago, Ryan_Tango said: Sounds like it's just rust scraping off it's normal until it does it all the time. As for the lip Now I've got it! Quote Link to comment Share on other sites More sharing options...
Albert27 Posted January 21, 2017 Author Share Posted January 21, 2017 2 minutes ago, iantt said: look ok to me also. my pads are far thinner than that. lol lol Thanks Ian, are you basing that off the second picture from beneath? Quote Link to comment Share on other sites More sharing options...
iantt Posted January 21, 2017 Share Posted January 21, 2017 based on all pictures. what we cant see is the inner face of disc but if its simular to the outer face then there ok for now. i will give you the specs . new brake disc thickness 25mm. worn minimum thickness 23mm pads minimum thickness 1.5mm. but i personally wouldnt go that low. 2 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted January 22, 2017 Author Share Posted January 22, 2017 15 hours ago, iantt said: based on all pictures. what we cant see is the inner face of disc but if its simular to the outer face then there ok for now. i will give you the specs . new brake disc thickness 25mm. worn minimum thickness 23mm pads minimum thickness 1.5mm. but i personally wouldnt go that low. Thanks. I just wanted to make sure I was looking at the brake pads from below (second picture) ! I think i'll take them out and have a good look at them, more so for the practice than anything. The inner pad on both ain't visible in the pics from top down and they both looked really thin so i guess to be on the safe side i'll measure them up & look for uneven wear I've noticed in haynes it says there's a risk of asbestos and to use a mask. I thought asbestos was only on old things! Is this accurate or are they being over safe? Quote Link to comment Share on other sites More sharing options...
mjt Posted January 22, 2017 Share Posted January 22, 2017 While you've got them out check the inner face of the discs. Corrosion can migrate outwards from the centre. This seems to be more prevalent on the inside face for some reason and reduces the effective area in which case they should be replaced. 3 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted February 4, 2017 Author Share Posted February 4, 2017 On 21/01/2017 at 5:30 PM, iantt said: based on all pictures. what we cant see is the inner face of disc but if its simular to the outer face then there ok for now. i will give you the specs . new brake disc thickness 25mm. worn minimum thickness 23mm pads minimum thickness 1.5mm. but i personally wouldnt go that low. Hi Ian, Shortly going to measure the thickness of the discs with a micrometer. Just to clarify, does the measurement include the small gap between the discs? Quote Link to comment Share on other sites More sharing options...
Gizza11 Posted February 4, 2017 Share Posted February 4, 2017 TBH they look a bit worn to me .The price of changing out the the disc's and pads are small why bother measuring the discs ,if you are worried change them out for peace of mind it's easy enough not so good in this cold weather though lol Quote Link to comment Share on other sites More sharing options...
iantt Posted February 4, 2017 Share Posted February 4, 2017 5 hours ago, Albert27 said: Hi Ian, Shortly going to measure the thickness of the discs with a micrometer. Just to clarify, does the measurement include the small gap between the discs? yes Quote Link to comment Share on other sites More sharing options...
