dickeygreen
New Exhaust - Does it need Paste?
Hi, I have fitted a new exhaust on my 2001 Mondeo Estate today, however when I look into it I couldn't find anything that said it needed paste between the joints...
Can anyone advised if the back joints need paste or not?
The front part has a gasket!
I would put a very small amount on the sleeve joints but nothing on the front joint as it should contain a round gasket/ring which crushes.
21 minutes ago, dickeygreen said:
balls that means I've got to get some now :)
Try it without you might get lucky if you have got good U clamps
i fitted a klarius exhaust not long ago on a mk3 estate and had to use paste, wouldn't seal without.
Yeah might just buy some tomorrow and fit it while its still on the ramps... only cost £2..
I'm guessing I need to remove the U clamps and put it inside! :)
Yep, take the exhaust apart and smear a small amount on the smaller diameter part of the sleeve joint and then slide the next section over it and fit the clamp.
i tend to cure the paste with a blow torch or heat gun whatever is handy as I find it always seems to wash out otherwise.
So went to get some fuelgum however they didn't have any.. Even though online said they had 1 gggrrr
So bloke in the shop said this is exactly the same. (attached photo)
