Dash cam hard wiring mondeo 2011
Russ 6334
 Share
Hi all
i have a 2011 mondeo with permanent live 12v sockets no good for a dash cam as it drains the battery when not in use!
i have a fuse tap however everything is permanent live or only intermittent live
ie i tried the ac but that's permanent live, wipers but only live when wipers are on, interior lights permenant live etc etc
i can't find anything that's ignition live even the stereo is permanent live!
any one know the fuse number that I can get a ignition live either under glove box or under bonnet
thanks
russ
Link to comment
Rear demister is not a blade fuse, checked the manual for fog lights there are no fuses for this? Odd I know
even the ignition switch F15 is permanent live
everything is permanent live!!
Link to comment
Try fuses 2,13, 21 or 24.
Another option is to tap off the lighter socket supply (fuse 7) and add a switch for manual operation.
I have a dashcam fitted to my Focus that I originally wired to the fusebox with a fusetap, however I often drive into areas where a dashcam is banned so instead I added a spare socket run from my original lighter socket whereby I can manually switch the supply on/off with a clear illuminated switch which can visually verify that the camera is off without fiddling around for the power button on the camera.
The original 12v plug to the camera is plugged in and tucked away under the dash with just the switched plug and a small spur of wire showing.
Link to comment
If it's anything like the mk5 it's not that they are all permanent live it's just some of them, like the 12v socket fuse, are delayed in powering down. The 12v socket stays live for approx 60mins after turning the ignition off. I have mine plugged in at all times, the amount of draw is negligible for that 60mins. Maybe try going back to the car after 90 minutes or so after killing the engine then checking the fuses again that you think should be switched.
  • Like 1
Link to comment
I have mine powered off the cigarette lighter fuse (2009 model). It starts up once I hit the open button on the key and shuts off after 2mins when the car is locked.
Is the 2011 model different?
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
