Focus washer jets
crossie2709
 Share
Need some help ive got some mist washer jets fitted on my mk2.5 focus had them one for a year or so and last few days they not been working properly its just dripping out
PS ive filled the washer bottle up [emoji1360]
Link to comment
My rear washer jet wasn't working recently.  I took it off and it was just blocked with rubbish and grime.  Take it off and give it a clean, I used a sewing needle -worked a treat!
Link to comment
Is there a noticeable difference in spray coverage compared to the original ones on a my 2.5? As I'm contemplating getting some.
Link to comment
They work they just not as good as the was
Link to comment
It sounds like filter block in the bottle due to screen wash. On my focus working fine then slowed down to like drip. Had to take wheel lining off to access the bottle.
Hope this helps
  • Like 1
Link to comment
As Madman says, there is a filter between the tank and pump that gets clogged up.
Remove the osf wheel, remove the rear part of the arch liner and you'll find the pump on the inward side of the lower part of the tank.
Pull off the pump and you'll be able to remove the filter.
Best done when the tank is empty or you'll end up with fluid everywhere :wacko:
  • Like 3
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
