Madmax12 Posted February 13, 2017 Share Posted February 13, 2017 Hello everyone,i have a fiesta MK6 2003,a couple of days ago i've fitted a universal central locking system from eBay,all good until today when the oil and battery lights came on in the dash,also the whole dash went off while i was driving.The lights only come on when the contact is in 2 position,after i start the engine they go off. I was told that could be a short circuit,what could cause this problems?. Quote Link to comment Share on other sites More sharing options...
mikeyd1 Posted February 14, 2017 Share Posted February 14, 2017 I think if they go off when the car is started then it's fine. It's sounds normal to me but I could be wrong Quote Link to comment Share on other sites More sharing options...
isetta Posted February 15, 2017 Share Posted February 15, 2017 query sounds confusing, but to elaborate on earlier answer: with ignition on and engine not running the battery light will be on to warn you that it is not charging (it can not charge if engine not running). when you start the engine, the battery light goes off if charging correctly. with ignition on and engine not running the oil pressure light will be on to warn you that there is no/low oil pressure (there can be no oil pressure if the engine is not running). when you start the engine, the oil pressure light goes off if the oil pressure is correct. If there was a short circuit I would have thought that should have blown a fuse somewhere meaning things could not return to normal until the fuse was replaced Quote Link to comment Share on other sites More sharing options...
