Dagger Posted February 23, 2017 Share Posted February 23, 2017 Hi Thought something was wrong coming back from work this morning Pulled over and the right hand side front bulb has blown So my question is: How easy is it to replace the bulb and the best type to get, may as well replace both with uprated ones Thanks Quote Link to comment Share on other sites More sharing options...
Hellboy80 Posted February 23, 2017 Share Posted February 23, 2017 The Mk1 is easy enough to change. Just one pain of a bolt underneath. You will need to get under the car to get to it. When I had my Mk1 I removed the bolt underneath and left it off. Quote Link to comment Share on other sites More sharing options...
williamweb Posted February 23, 2017 Share Posted February 23, 2017 Yours is the face lift with integrated lights?if so,to be honest I find the easiest way is to open up the bonnet undo the top light fixings and dislocate the light unit,remembering the unit is connected by wires.At the back of the unit you can see a cover secured in place by a wire clip,release the clip and pop the cover off ,you now have access to the bulbs.Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
Albert27 Posted February 23, 2017 Share Posted February 23, 2017 8 hours ago, Dagger said: How easy is it to replace the bulb and the best type to get I tried the 120% more lights bulbs but they would never last. I don't know if I was unlucky but they would blow after a month. I stick to thesrandard ones off eurocarparts or if they're a bit pricey (wanted £3.50 per bulb recently), get them off amazon for £1.64 a piece. Whether they'll stand the test of time, I wait to see! Quote Link to comment Share on other sites More sharing options...
Hellboy80 Posted February 23, 2017 Share Posted February 23, 2017 5 hours ago, williamweb said: Yours is the face lift with integrated lights?if so,to be honest I find the easiest way is to open up the bonnet undo the top light fixings and dislocate the light unit,remembering the unit is connected by wires.At the back of the unit you can see a cover secured in place by a wire clip,free the cover from the clip and you have access to the bulbs. Sent from my iPad using Ford OC There is a third bolt underneath to. 1 Quote Link to comment Share on other sites More sharing options...
Dagger Posted February 23, 2017 Author Share Posted February 23, 2017 What fitment would I need , looked on Europarts and there's 3 types: H1 H4 H7 Thanks Quote Link to comment Share on other sites More sharing options...
Hellboy80 Posted February 23, 2017 Share Posted February 23, 2017 H7 for dipped and h1 for main beam. Quote Link to comment Share on other sites More sharing options...
Dagger Posted March 7, 2017 Author Share Posted March 7, 2017 Thanks Guys Done it, and it was really easy, didn't need to remove the whole light unit, managed to get my hand behind and just pop off the cover Thanks 1 Quote Link to comment Share on other sites More sharing options...
mjt Posted March 7, 2017 Share Posted March 7, 2017 You must have girls hands I've never managed it without removing the headlamp. 1 Quote Link to comment Share on other sites More sharing options...
Dagger Posted March 8, 2017 Author Share Posted March 8, 2017 8 hours ago, mjt said: You must have girls hands I've never managed it without removing the headlamp. LOL The drivers side one is easy, but the other side I guess would be a lot more difficult and would require removal of the entire headlamp Quote Link to comment Share on other sites More sharing options...
