Budgie650 Posted December 14, 2009 Share Posted December 14, 2009 After servicing my 52 plate Ka,changed plugs,oil change,air filter change,the engine now misfires when putting your foot down,could it be a dud spark plug,or the HT leads. Quote Link to comment Share on other sites More sharing options...
roger4321 Posted December 20, 2009 Share Posted December 20, 2009 After servicing my 52 plate Ka,changed plugs,oil change,air filter change,the engine now misfires when putting your foot down,could it be a dud spark plug,or the HT leads. Did you check the gaps on the plugs when fitting them? Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted December 20, 2009 Share Posted December 20, 2009 plugs now come ready gapped...could be got the wrong plugs! Did you get some grease on an electrode maybe? or the HT leads not quite clipped on? Quote Link to comment Share on other sites More sharing options...
Budgie650 Posted December 22, 2009 Author Share Posted December 22, 2009 Did you check the gaps on the plugs when fitting them? yes checked the gaps with feeler gauges Quote Link to comment Share on other sites More sharing options...
Budgie650 Posted December 22, 2009 Author Share Posted December 22, 2009 Did you check the gaps on the plugs when fitting them? Yes i set up the gaps with feeler gauges Quote Link to comment Share on other sites More sharing options...
Budgie650 Posted December 22, 2009 Author Share Posted December 22, 2009 plugs now come ready gapped...could be got the wrong plugs!Did you get some grease on an electrode maybe? or the HT leads not quite clipped on? Fitted the right plugs,no grease on the electrode,and the HT leads are all fitted correctly. Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted December 22, 2009 Share Posted December 22, 2009 Does it miss at idle??? If so, remove the leads one at a time as its running, (then replace obviously!) and see which one makes NO difference to the misfire...then turn engine off and inspect plug...see what colour it is, and look VERY carefully at the ceramic...may have the tiniest of cracks! what make of plugs did you use? also, if it does miss at idle...take it to the darkest place possible, lift bonnet, turn all lights off and look out for any little lightening jumps from the Ht leads/coil to the engine :) Piggy :) Quote Link to comment Share on other sites More sharing options...
Budgie650 Posted January 10, 2010 Author Share Posted January 10, 2010 Does it miss at idle???If so, remove the leads one at a time as its running, (then replace obviously!) and see which one makes NO difference to the misfire...then turn engine off and inspect plug...see what colour it is, and look VERY carefully at the ceramic...may have the tiniest of cracks! what make of plugs did you use? also, if it does miss at idle...take it to the darkest place possible, lift bonnet, turn all lights off and look out for any little lightening jumps from the Ht leads/coil to the engine :) Piggy :) Engine does not misfire on tickover,have removed plugs one by one all nice colour no obvious cracks on ceramic,could i have a dud spark plug Quote Link to comment Share on other sites More sharing options...
aquila Posted January 16, 2010 Share Posted January 16, 2010 Last time I had a misfire it was the ignition coil ;) Quote Link to comment Share on other sites More sharing options...
