Fiesta lowing springs
NeXorek_MK7
 Share
Hello all,
I'm looking after lowering my fiesta, I decided to go for lowering springs as they are cheaper comparing to coilovers. If I was going to fit them do I need to get anything done on top of that? What I mean by that do I need a new alignment or mess with the struts or anything like that? Never done it before so I wanna know everything before hand, and if anyone has any recommendations of what springs to go for let me know
Thank you for any help,
Link to comment
Read on the forum that its advisable to change the actual strut as the ram is too long.
Link to comment
If you have the Zetec S suspension you won't need new struts for 25-35mm lowering springs. If lower then take the advice of the spring manufacturer. You will need an alignment once the springs have settled.
Link to comment
If you just change the springs every time you hit a bump on the road or a speed bump it will feel as if the suspension has bottomed out with a big nasty jolt. It will spoil the ride of the car and you will soon be wanting to put it back. The best way is to change the struts at the same time   .I am looking to do mine but I, having the struts done to (adjustable).Mine would cost about £800 ish fitted( they are adjustable) to do front and back. I've bin there and done just springs in the past so I know I'm right. On saying that there are lots to choose from depending on what your needs are (hard /soft/adjustable) when done right will make a big difference to the handling of your car.
  • Like 1
Link to comment
How much do you want to lower it by?? A very moderate lowering, such as Eibach Pro-sport springs (which are designed to work with OEM shocks), won't require other changes. Springs start at £140, about the same for fitting and then allow about £50 for alignment. Plus any insurance change costs.
Link to comment
Yeah these were the ones I was gonna go with, fairly low price and if they work with the OEM shocks then it's a win win. Thanks
Link to comment
Alright thanks people, I'll see how it looks from the side of the warranty, I've read that as long as they are fitted by the ford approved garage then it shouldn't break my warranty. Thanks you all for your help!
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
