kikey Posted December 15, 2009 Share Posted December 15, 2009 can any help just started today was running fine filled up with diesel now over 3000 revs it has like a misfire and very lumpy fine at tick over thanks mike Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted December 16, 2009 Share Posted December 16, 2009 Could be fuel pump on its way out or injectors. 3krpm in a diesel is very hard driving. I normally aim to change up by 2000-2500 rpm, dont forget the TDDi "redlines" at just over 4000rpm Quote Link to comment Share on other sites More sharing options...
kikey Posted December 23, 2009 Author Share Posted December 23, 2009 Could be fuel pump on its way out or injectors. 3krpm in a diesel is very hard driving. I normally aim to change up by 2000-2500 rpm, dont forget the TDDi "redlines" at just over 4000rpm had a freind check my car with a fault reader comes up with P0149 -fuel timing error car running very bad will not rev and a lot of blue white smoke unburnt fuel i was told i got a new timing belt fitted about a month ago is this any thing to do with it not loosing water or oil hope some one can help thanks mike Quote Link to comment Share on other sites More sharing options...
artscot79 Posted December 23, 2009 Share Posted December 23, 2009 the electric feed pump near the fuel tank. is the culprit so it is indeed fuel pump related and not the timing ive scoured the internet and all codes p0149 were resolved by replacing this part. Quote Link to comment Share on other sites More sharing options...
ToolBox Posted December 23, 2009 Share Posted December 23, 2009 You didnt by any chance put petrol in it, a diesel will usualy run with a fair petrol to diesel mix but they smoke have no power and are hard starting. Quote Link to comment Share on other sites More sharing options...
