New wing bolt on or weld ?
Richardhart90
 Share
Hi all
Looking at buying a KA edge, see picture for damage
Basically needs a new bumper and wing, main question is are the wings spot welded with bolts on or just bolted ?
If spot welded do they need to be re spot welded or will few bolts as well be ok to hold it on ?
Also any advice on what its worth as it is, what would you buy it for i you where buying it ?
KA Edge
2014
3,156 miles
1 owner
cheers
Rich
Link to comment
as its the edge model i would not bother.
you will need it jigged incase the chassis is bent and
the front section check to see if
the chassis where the suspension is hel in place has not been damaged then
after carrying out all the work needed it needs re registering with the dvla and a new mot
as it was more than likely a write off as it looks like the wheel has taken a heavy knock
i personally would not bother.
the cost of the work etc you may aswell buy one thats up together unless
you like a project to take on
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
