Richardhart90 Posted March 8, 2017 Share Posted March 8, 2017 Hi all Looking at buying a KA edge, see picture for damage Basically needs a new bumper and wing, main question is are the wings spot welded with bolts on or just bolted ? If spot welded do they need to be re spot welded or will few bolts as well be ok to hold it on ? Also any advice on what its worth as it is, what would you buy it for i you where buying it ? KA Edge 2014 3,156 miles 1 owner cheers Rich Quote Link to comment Share on other sites More sharing options...
delboy Posted March 9, 2017 Share Posted March 9, 2017 as its the edge model i would not bother. you will need it jigged incase the chassis is bent and the front section check to see if the chassis where the suspension is hel in place has not been damaged then after carrying out all the work needed it needs re registering with the dvla and a new mot as it was more than likely a write off as it looks like the wheel has taken a heavy knock i personally would not bother. the cost of the work etc you may aswell buy one thats up together unless you like a project to take on Quote Link to comment Share on other sites More sharing options...
