Chris_W Posted March 20, 2017 Share Posted March 20, 2017 Hi al! Was rooting wire for dash cam earlier, however i decided to press pedals to see if all was fine, however the brake pedal presses in when off and makes a air/hiss sound, press again and again until it gets firm. then i started engine ans same air/hiss noise few presses then firmer. I have never checked this so is this normal or is this a serious fault/issue? surely its not the wire I traced around car, under center of dash to rear under the arm rest? Quote Link to comment Share on other sites More sharing options...
dezwez Posted March 20, 2017 Share Posted March 20, 2017 its normal Quote Link to comment Share on other sites More sharing options...
Chris_W Posted March 20, 2017 Author Share Posted March 20, 2017 3 minutes ago, dezwez said: its normal I HOPE SO HAHA I have only just noticed this, just worried in case its brake failure or something else? Its definitely normal and not something to worry about? Quote Link to comment Share on other sites More sharing options...
dezwez Posted March 20, 2017 Share Posted March 20, 2017 take for a run the brakes will be the same as they were Quote Link to comment Share on other sites More sharing options...
Chris_W Posted March 20, 2017 Author Share Posted March 20, 2017 @dezwez thanks will give a go a bit! Quote Link to comment Share on other sites More sharing options...
