PhilS404 Posted March 28, 2017 Author Share Posted March 28, 2017 14 hours ago, fraserrg said: car looks good, plenty of money been put into it! Thanks mate! Hahah yes, thank fully I have bought most parts second hand so saved a big chunk! Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted March 28, 2017 Author Share Posted March 28, 2017 My HID Kit decided to break to picked up another one and got those installed. Only 6000k Gave the car a well deserved wash and also fitted a one way valve into the crankcase breather as boost pressure was getting pushed from the inlet into the crankcase. Not good! 1 Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted March 28, 2017 Author Share Posted March 28, 2017 Thought it was also about time I did some bits to the interior. So managed to find a top tray to replace the original screen, and also a different fascia which angles the screen towards me. Both parts were the sprayed gloss black, and redid my door handles Dirty engine bay 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted March 29, 2017 Share Posted March 29, 2017 8 hours ago, PhilS404 said: Thanks mate! Hahah yes, thank fully I have bought most parts second hand so saved a big chunk! where from? Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted March 30, 2017 Author Share Posted March 30, 2017 On 29/03/2017 at 8:36 AM, fraserrg said: where from? Just from the mk7fiesta.co.uk page on facebook. That's where I've bought most my stuff from. And couple things off eBay. Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted April 9, 2017 Author Share Posted April 9, 2017 Door handles now fitted along with new fascia Also kinda had a disaster with the supercharger. Snapped shaft...oops. So it was onto Komotec in Germany who make the kit to find a replacement. The charger failure was due to overheating due to a lack of an oil cooler. For some reason they don't include one in the kit, but it's a lesson learnt. Dodgy idle pulley Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted April 9, 2017 Author Share Posted April 9, 2017 So whilst I was trying to sort out the charger I just ran the car with the original belt and induction kit. Car ran fine with the larger injectors just very rich. Still had time to attend a car show with some mates Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted May 10, 2017 Author Share Posted May 10, 2017 Good news, supercharger replaced under warranty for free. Oooh shiny I also fitted a Setrab oil cooler to keep the charger oil cool (was meant to have one all along, oops). Boost piping relocated behind the crash bar. I also removed the air restrictor to get a bit more power out of it, injectors can compensate 15% either way so it kept the AFR at 12.1 WOT Also picked up a replacement intercooler as mine was full of turbine shards for a tenner off my mate Some picture showing the charger placement for those interested. It's very easy to do, I took it off whilst engine in car in 45 mins. (not my car) oil reservoir was also moved so it wasn't a foot above the charger, this is under drivers side headlight 1 Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted May 10, 2017 Author Share Posted May 10, 2017 A little mountune sticker for the car. It only drinks 99 so the 95 should really be a sad face. Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted May 10, 2017 Author Share Posted May 10, 2017 Right so having some troubles with the extra boost, there was a bit of surge before removing the air restrictor but now it's causing the charger to stall. Yes it makes a cool chatter noise but it's not good for the charger, and I don't think i'll be lucky enough to get another one one warranty. Rang up TTS who are the UK Rotrex dealers and they were very helpful, advised to fit a BOV. Popped down to demon tweeks, picked up a Forge valve, vacuum piping and a T-piece. Also bought a larger filter from Ram Air. I tapped into the fuel vapour recirc before the one way valve, it was a bit of a pain but a hot brew softened the pipe which is plastic. It's not the tidiest, I will tidy it up at some point when I have the time, I did buy some yellow hose wrap from Demon Tweeks but it's quite difficult to use. 2 Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted May 11, 2017 Share Posted May 11, 2017 7 hours ago, PhilS404 said: 7 hours ago, PhilS404 said: I also fitted a Setrab oil cooler to keep the charger oil cool (was meant to have one all along, oops). Boost piping relocated behind the crash bar. I'd be interested in knowing more about your fitting of the oil cooler. What type of sandwich plate did you use? Did you remove the OEM cooler? Hose routing, etc. Thanks. Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted May 11, 2017 Author Share Posted May 11, 2017 17 hours ago, ThaiFiesta said: I'd be interested in knowing more about your fitting of the oil cooler. What type of sandwich plate did you use? Did you remove the OEM cooler? Hose routing, etc. Thanks. Hi mate, the oil cooler is only for the supercharger to cool the traction oil. 1 Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted May 13, 2017 Author Share Posted May 13, 2017 Picked up an ST headlining from Birmingham along with the trims which I'd had sitting around for a few months. Quite easy to install took about 45 mins maybe, and looks 10x better than the grey. Sorry some pics are a bit poor. 1 Quote Link to comment Share on other sites More sharing options...
b4zz Posted May 14, 2017 Share Posted May 14, 2017 liking the interior change to the st parts Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted May 15, 2017 Author Share Posted May 15, 2017 14 hours ago, b4zz said: liking the interior change to the st parts Yeah it's such a nicer place to be with the black. Quote Link to comment Share on other sites More sharing options...
yunii Posted May 15, 2017 Share Posted May 15, 2017 Much better now. I did this in my focus ftting st225 trim but not headlining yet . It gives you upmarket feel.YuniiSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted May 16, 2017 Author Share Posted May 16, 2017 Some stupid women decided she couldn't parralel park and scraped down side of my car then denied it. Police useless so had to pay out my own pocket. £100 and also got car machine polished. 1 Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted May 20, 2017 Author Share Posted May 20, 2017 Time for a bit more stopping power. 300mm focus ST170 discs with mondeo calipers, Brembo pads and brackets. I got these second hand off the forum for £170, and the seller then bought me new discs (old ones in first pic). I sold the clear HEL lines and got some yellow ones to match the calipers I painted. Snapped the bolt trying to get braided line out of the caliper so had to get the blow torch on it and molegrips. Old disc compared to new Dyno run up next! Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted May 26, 2017 Author Share Posted May 26, 2017 Had the car serviced and on the dyno at Zi Motorsport in Wrexham. Very please with the results! The car made it's standard power at 4000. With max power at 215bhp so very pleased. Still, room for improvement. 2 Quote Link to comment Share on other sites More sharing options...
Tom-B64 Posted June 8, 2017 Share Posted June 8, 2017 Very nice mate. Sits really nice! 1 Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted September 16, 2017 Author Share Posted September 16, 2017 Right back to it! Finally fitted the Aerial to the headunit so I can have the radio in the car. Also fitted the hazard switch after losing the first one I bought Also picked up some Boomba spoiler raisers, very marmite to begin with but after a while I really liked them, help make the rear more aggressive. Without spoiler XD haha And with raisers 1 Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted September 16, 2017 Author Share Posted September 16, 2017 Also picked up a zunsport grill, second hand again. Helps with the airflow. Normally it's hard to pull of a zunsport on the prefacelift because it's just crash bar behind. With the intercooler and oil cooler it looks better! Some picture from a car meet up the horseshoe pass Picked up a very rare Mountune MR155 front apron which was a pain to bond on. A bit different to the usual TRC splitters Grey overlays to match the wheels Quote Link to comment Share on other sites More sharing options...
Bobr Posted September 16, 2017 Share Posted September 16, 2017 You've obviously done a terrific job. I'd be interested to know what difference it has made to your insurance. 1 Quote Link to comment Share on other sites More sharing options...
PhilS404 Posted September 17, 2017 Author Share Posted September 17, 2017 19 hours ago, Bobr said: You've obviously done a terrific job. I'd be interested to know what difference it has made to your insurance. Insurance isn't too bad. Visual mods don't affect the policy with mine. And they know I've uprated the brakes etc, so it's not really changed. Might be just because I've also gotten older and more NCB. Quote Link to comment Share on other sites More sharing options...
yunii Posted September 18, 2017 Share Posted September 18, 2017 Right back to it! Finally fitted the Aerial to the headunit so I can have the radio in the car. Also fitted the hazard switch after losing the first one I bought Also picked up some Boomba spoiler raisers, very marmite to begin with but after a while I really liked them, help make the rear more aggressive. Without spoiler XD haha And with raisers Hi, i like the pioneer stereo. Can i ask where did you get the top screen surround to fit the pioneer? Also does the stock piano black radio facia remaim or does that has to be changed?YuniiSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
