marco.da.man
ford puma rear bush removal
hello guys i fought id but a little help for rear bush removal
step 1 with rear axel on or off, prize of plasrtic ring either side using flat heade screw driver
step 2 cut out rubber inside using a hacksaw and knock through with mallet
step 3 using hacksaw cut a slit into metal of bush but carefull not going to far as in through rear axel
step 4 using a cold chisel and hammer knock down cut to open up and losen
step 5 this should losen enough to knock rest off bush out
hope this helps all
