Support the club!
replacing a heater matrix mk5 fiesta
4 replies to this topic
#1 paulliver
paulliver
    Newbie
  • Pip
  • 7 posts
  • Ford Model: fiesta
Posted 25 December 2009 - 07:05 PM
the wifes heater matrix is blocked so im thinking of changing it anybody done the above and how did you do it
cheers paul
#2 InstructorPiggy
InstructorPiggy
  • 981 posts
  • Ford Model: Fiesta Mk7 TDCI ZS
Posted 25 December 2009 - 08:31 PM
Hey, not a difficult job, just time consuming and fiddliy!
It requires removal of the dashboard...remoaval of part of heater system, block off matrix pipes, then remove matrix.
Replace, partly refit heater system and sit dash in place, then top up coolant system, run engine and bleed system and ensure matrix not leaking!
Run engine ensuring no air locks and matrix gets warm, then you can fit dash back fully :)
Expect spending a good day! :)
#3 stevej2209
stevej2209
    Newbie
  • Pip
  • 1 posts
  • Ford Model: 1.25 Zetec Mark 5
Posted 29 December 2009 - 02:48 PM
cheers paul
You don't need to remove the dash at all, it takes about an hour to do. Look under the bonnet to the back and centre of the vehicle, you'll see two pipes leading through a soft covering. Follow the pipes and you should see them attached to a removable plate held in by 4 screws, that's where the heater matrix sits. Any more help just give me a message.
#4 paulliver
paulliver
    Newbie
  • Pip
  • 7 posts
Posted 29 December 2009 - 08:14 PM
hi steve sent u a message
thanks paul
#5 paulliver
paulliver
    Newbie
  • Pip
  • 7 posts
Posted 03 January 2010 - 05:58 PM
did what u said m8 didnt take long,i flushed a load of rust /crap out of the matrix refitted it and hey presto???now have hot air blowing :)
im thinking of dropping all of the coolant out when it get a bit warmer then refilling it all with fresh .i will flush the radiator and heater matrix out first then add fresh anti-freeze and water should be fine
thanks for the help
paul
