Ranger pcd
2 replies to this topic
#1 hitch
hitch
    Newbie
  • Pip
  • 2 posts
  • Ford Model: transit, fiesta
Posted 27 December 2009 - 01:19 PM
What PCD is the 6 stud ford ranger 2003/4 model please
#2 macboatmaster
macboatmaster
    Member
  • PipPip
  • 13 posts
  • Ford Model: ranger double cab xlt thunder
Posted 01 January 2010 - 11:33 PM
Here is your answer from the workshop manual. Hope it helps. Macboatmaster
TECHNICAL DATA
TD–14
General
Item 42 44
Size
Front 185R14C- 195R14C- 205R16C- 235/75R15
P235/75R1
P235/75R1
Rear
185R14C
8PR
195R14C
8PR
205R16C
8PR
105S
5 105S
5 106S
Front
Unloade
d
(Up to
full
passenger
180
{1.8, 26}
180
{1.8, 26}
180 {1.8, 26}
Tire Air pressure
Loaded
(Full
loaded)
200
{2.0, 28}
200
{2.0, 28}
ressure
(kPa {kgf/cm2, psi})
Rear
Unloade
d
(Up to
full
passenger
180 {1.8, 26}
Loaded
(Full
loaded)
450 {4.5, 63} 250
{2.5, 35}
240
{2.4, 34}
260
{2.6, 36}
Wear limit (mm {in}) 1.6 {0.06}
Wheel
Size 145J
145J
145
1/2J
166JJ 156 1/2JJ
Offset (mm {in}) 40 {1.57} 35 {1.38} 25 {0.98}
Pitch circle diameter (mm {in}) 139.7 {5.45}
Tightening torque
(N·m {kgf·cm, in·lbf})
Standard wheel: 89—117 {9—12, 65—86}
Styled wheel (166JJ): 118—147 {12—15, 87—108}
Wheel
and tire Runout limit (mm {in})
Horizontal 2.0 {0.078}
Vertical 1.5 {0.059}
Imbalance limit (g {oz}) 10 {0.35}
 One balance weight: max. 60 g {2.1 oz}.
 If the total weight exceeds 100 g {3.5 oz} on one side, rebalance after moving the tire around on the rim.
 Do not use more than two balance weights on the inner or outer side of the wheel.
#3 hitch
hitch
    Newbie
  • Pip
  • 2 posts
Posted 07 January 2010 - 10:13 PM
so its a 6 stud 139.7mm
i was wondering because i was looking to fit some 6 spoke steel weller wheels, (like landrover defender style) but drilled to 6 stud, with some offroad tires
would it work do you recon?? or would the offset stick out to wide, as i have never seen a ranger with wide offroad tires always skinny offroad tires on standard rims, which are well hidden in the arches
Hitch
