Paddy94
Focus MK2 Drivebelt?
Hey guys.
Leaving my car in to get the timing belt and water pump done next week and I'm wanting to get the main drive belt done as well. My car has aircon, so i think it has two different belts? The air con belt looks almost new but the main belt (Alternator, water pump, etc) is looking a bit worse for wear. What I'm wondering is, is it possible to just change the one belt? Or will I need to change both?
Also, I've been looking at belts on eurocarparts and was wondering if this one would fit? http://www.eurocarparts.com/ecp/c/Ford_Focus_1.6_2005/p/car-parts/belts-chains-and-tensioners/engine-parts/car-drive-belt/?202777285&1&0d3d200c076dbb0a8307066a2f3f98037cabac16&000108
Thanks.
49 minutes ago, Paddy94 said:
Hey guys.
Thanks.
There are two separate belts on my diesel focus. One is the timing belt and the most important belt to change because if it snaps you'll likely end up with a damaged engine.  The second belt is the auxilliary belt or Drive belt that runs round the alternator and air con etc..  Some garages will change the drive belt at the same time as they have to take it off to get access to the timing belt but best to check with them if you wanted it changed.  The interval for the drive belt change on my focus is 125,000 or 10 years I think.  Hope that helps.
He Might have a 1.6 Petrol, I don't know what the configuration for the aircon and alternator is for that.  I wouldn't recommend leaving your timing belt to 125k tho, I changed mine about 75, the close to 125 you get the move chance it can go wrong, not sure its something I would want to take any chances on tbh!
Since you need to take the aux belt(s) off to get the timing belt sorted, then it seems daft not to change them at the same time, but do you need to? nope
The 1.6 Duratec Petrol engine has 2 different drive belts.
Afbeeldingsresultaat voor focus duratec drive belts
The 1st drive belt drives the water pump and the alternator and the 2nd drive belt drives the airconditioning pump. Both belts are stretch belts without tensioners. Stretch belts can officially only be installed once (however there are ways to reuse them). Ford prescribes to remove the belts by cutting them.
Personally I would not even bother to reuse the stretch belts. The stretch belts are pretty inexpensive and reusing them will void any warranty on the timing belt change. If a stretch belt snaps it potentionally can cut the timing belt cover and timing belt which will cause serious engine damage.
Haynes reckon about that too, i think it's 62500 in the book.  I got mine done around the 80k mark and just in time according to the mechanic.
i don't think you can. as said in posts above it is a stretch belt. it is installed with a special guide that feeds belt on to pulleys as you turn them. and it is removed by cutting off.
Is the 1.6 petrol a 16v then? I know little really but looks like dohc from that pic?
Hey , could anyone point out the waterpump position in this photo ?
i have the same engine and need to keep an eye on a shoddy dealership repair  lol  :biggrin:
2 minutes ago, biff55 said:
Hey , could anyone point out the waterpump position in this photo ,  i've got a shoddy dealership repair i need to keep an eye on lol  :biggrin:
Just under the engine mount, to the right. Flat pulley with 4 bolts.
Thank you guys for the confirmation. I figured it was a stretch belt from deep research and a whole day staring under the hood looking at the engine to find an adjuster lool
A little on topic, useful with the engine picture. Where would you support the engine from underneath whilst replacing the right engine mount? The haynes manual just refers to using a jack with a block of wood but does not specify where is safe to do this.
I also notice there is a position for an engine crane? on the top left which I can probably borrow for 10 minutes whilst at work if it would be more suitable to support the engine (and the advantage of not having to remove the engine undershield!).
