moorea Posted May 9, 2017 Share Posted May 9, 2017 Hi, my Focus (1.6 petrol 10 plate) whilst on the motorway started making a loud noise from the engine and when i went under 10mph my car kept stalling/cutting out, when i opened up the bonnet it was vibrating excessively. Does anybody have any idea what the problem could be? Quote Link to comment Share on other sites More sharing options...
JONATHAN_11_80 Posted May 9, 2017 Share Posted May 9, 2017 Depends on the noise to be honest does it knock when you rev it up and the let the revs drop if it does I expect you have ran it low on oil. So my first check would be the oil level. If the oil level is ok when was it last changed. To be honest we need more information on the noise is it a knocking or tapping noise does it occur when under load or when you come off the throttle. 1 Quote Link to comment Share on other sites More sharing options...
isetta Posted May 9, 2017 Share Posted May 9, 2017 it might only be running on 3 cylinders (which would cause it to vibrate) but there are many many things which would cause that from minor to major. Hole in a piston, a problem with the valves, spark plug blew out because it wasn't done up etc etc etc 2 Quote Link to comment Share on other sites More sharing options...
TangoDaz Posted May 9, 2017 Share Posted May 9, 2017 Could be the coil pack or fault spark plug 1 Quote Link to comment Share on other sites More sharing options...
TangoDaz Posted May 9, 2017 Share Posted May 9, 2017 If you suspect a hole in the piston then you will need to do a compression test hope it's just a coil pack or plug 1 Quote Link to comment Share on other sites More sharing options...
