wilto Posted May 21, 2017 Share Posted May 21, 2017 Hi guys. Got a 2010 Ford Focus 1.8 with the IB5 gearbox. Recently noticed that the gearbox breather vent was loose on top of the gearbox, and there is oil over the gearbox casing. This has a clip on the side and I cant find where to clip it. Any ideas, thanks in advance Chris Quote Link to comment Share on other sites More sharing options...
dezwez Posted May 21, 2017 Share Posted May 21, 2017 it clips just inside the gear box mounting on that side Quote Link to comment Share on other sites More sharing options...
wilto Posted May 21, 2017 Author Share Posted May 21, 2017 Cheers pal, I'll see if I can locate the mounting. 🤞 1 Quote Link to comment Share on other sites More sharing options...
JONATHAN_11_80 Posted May 22, 2017 Share Posted May 22, 2017 Ive got got the same issue anyone got a pictures where it clips too. Cheers. 1 Quote Link to comment Share on other sites More sharing options...
wilto Posted May 23, 2017 Author Share Posted May 23, 2017 On 2017-5-21 at 2:18 PM, dezwez said: it clips just inside the gear box mounting on that side Hi Dez, is it possible you can get a pic or diagram as to where it goes mate, would be awesome if you could, cheers mate.👍 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted May 23, 2017 Share Posted May 23, 2017 Hi I clip mine here in the picture this mount is under the battery box which I took out there is a plate over the top of this but you should be able to fit it between the two plates good luck 1 Quote Link to comment Share on other sites More sharing options...
wilto Posted May 24, 2017 Author Share Posted May 24, 2017 Cheers Dez, nice one 👍 Quote Link to comment Share on other sites More sharing options...
