Can I add front foglamps to my Mk 2 Focus LX easily ?
vijilants
 Share
I own a Mk2 Focus LX but it has no front foglamps.
Is it possible to add these and is it an easy upgrade and if so, what's involved ?
Many Thanks
  • Like 2
Link to comment
I think the wiring is under the front somewhere may need to take a good look around and you may need to uprate
the light switch if there is no front fog light marking on your old one   :smile:
  • Like 1
Link to comment
The front foglight wiring is not always present on a Focus MK2/MK2.5 without front foglights. If the foglight wiring is not present it needs to be installed. Ford used to sell the front foglight wiring harness as an accessoire part but unfortunately this wiring harness is currently no longer available. This basically means that when the front foglight wiring is not present you either have to take the wiring harness out of a scrap car or you have to make the wiring harness yourself.
  • Like 1
Link to comment
Still available here: http://fordpartsuk.com/shop/ford_focus_mk2_front_fog_lamps_wiring_loom_f_1599361.htm
Link to comment
If wiring is there; then you just need the fog light kit
Mk2 kit
Mk2.5 kit:
but if theres no wiring there; then you will also need the Wiring loom it's the same for both mk2 & mk2.5 models:
Link to comment
Thank you all.
I think I can find the foglamps cheaper on eBay and probably the wiring loom.
Just though that maybe it was pre wired and it would be a simple task of plugging in the fog lights.
  • Like 1
Link to comment
22 minutes ago, biff55 said:
50 sodding quid ??!!
i could knock 1 up in 10 minutes flat...........
Make a few and sell em for 25 nice profit 👍
  • Like 1
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
