MJNewton Posted September 4, 2017 Share Posted September 4, 2017 What did you use to attach the sensor to the bottle? (some sort of adhesive by the looks of it?) Quote Link to comment Share on other sites More sharing options...
540itouring Posted September 4, 2017 Author Share Posted September 4, 2017 I used JB WELD as it can stand up to 287 deg. I used a thin film between the bottle as to not alter the sensing of the water and a thicker ring around and is rock solid and has now been fitted for some time now. what do you think of the warning system ? Quote Link to comment Share on other sites More sharing options...
MJNewton Posted September 4, 2017 Share Posted September 4, 2017 Thanks, and yeah it's good! I think I would've tapped in to the 'bonnet open' circuit as it'd more likely get a prompt reaction from my wife if she was driving rather than just casually mentionong that 'the brakes needs servicing or something' if/when she got home! Quote Link to comment Share on other sites More sharing options...
540itouring Posted September 4, 2017 Author Share Posted September 4, 2017 yes I am sure you could to that but you would have to have low resistance switching to make sure as I expect that the alarm uses that switch. The way I have done it it just switches a resistor in parallel to trip the warning so the low brake fluid will also still work as normal. I have all electronic mods completed now so need to find some time to clean the car up now . I have leart a bit more from playing with Forscan and now makes more sense to me. 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted September 4, 2017 Share Posted September 4, 2017 can you post up the electronic side of it with resistor value so if any one want to do the same, they can be prepared to the extent of whats required? 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted September 10, 2017 Share Posted September 10, 2017 Nice job ! I am currently busy developing a low coolant warning system for my focus MK3. I will use a contactless fluid level sensor which is connected to an Arduino microprocessor with CANbus shield. This way I will (hopefully) be able to send the correct CANbus messages to the instrument cluster to activate the appropriate warning lights. I did some CANbus sniffing on the car and obtained most of the CANbus data I need. Using this CANbus data I am able to send some CANbus messages to a spare instrument cluster while testing on the table. Using these CANbus messages I can switch on the instrument cluster and switch most of the warning lights and messages on and off. 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted September 10, 2017 Share Posted September 10, 2017 i googled and the us there appears to be a issue that requires a ford retroffited coolant level sensor on certain 1.6 ecoboost. i wonder what that kit will look like. Quote Link to comment Share on other sites More sharing options...
MJNewton Posted September 10, 2017 Share Posted September 10, 2017 Probably part of the pressure cap. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted September 10, 2017 Share Posted September 10, 2017 2 hours ago, iantt said: i googled and the us there appears to be a issue that requires a ford retroffited coolant level sensor on certain 1.6 ecoboost. i wonder what that kit will look like. I also read several articles about this subject recently. From what I read the issue is still under investigation and Ford has not released a final solution yet. It is a safety recall because of fire risk. Loosing coolant results in an overheated engine which caused the cilinder head to crack. The cracked cilinder head can cause engine oil leaking onto the hot exhaust which can result in fire. The recall applies to the following vehicles equipped with the 1.6 GTDI (ECOboost) engine: 2014 Escape – Louisville Assembly Plant, Feb. 12, 2013 to Sept. 2, 2014 2014-15 Fiesta ST – Cuautitlan Assembly Plant, Jan. 22, 2013 to May 27, 2014 2013-14 Fusion – Hermosillo Assembly Plant, Feb. 15, 2012 to June 6, 2014 2013-15 Transit Connect – Valencia Assembly Plant, June 13, 2013 to Dec. 14, 2014 The official recall information can be found on the following link: https://static.nhtsa.gov/odi/rcl/2017/RCMN-17V209-3326.pdf Quote Link to comment Share on other sites More sharing options...
iantt Posted September 10, 2017 Share Posted September 10, 2017 maybe that fix when released could be made to fit our 1.0 ecoboost cars Quote Link to comment Share on other sites More sharing options...
MJNewton Posted September 10, 2017 Share Posted September 10, 2017 It could make for a quite a neat solution. I suppose we'd be missing the PCM update that presumably will be required to interface with it but one of the piggyback ideas discussed here ought to suffice. Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted September 22, 2017 Share Posted September 22, 2017 On 10/09/2017 at 3:49 PM, iantt said: i googled and the us there appears to be a issue that requires a ford retroffited coolant level sensor on certain 1.6 ecoboost. i wonder what that kit will look like. Have you heard anymore about this? Quote Link to comment Share on other sites More sharing options...
iantt Posted September 22, 2017 Share Posted September 22, 2017 nope Quote Link to comment Share on other sites More sharing options...
biff55 Posted September 23, 2017 Share Posted September 23, 2017 On 9/10/2017 at 9:49 AM, iantt said: i wonder what that kit will look like. a bucket and a bit of pipe linked to an egg timer as a warning buzzer. ford price £130. :-D 1 Quote Link to comment Share on other sites More sharing options...
540itouring Posted September 23, 2017 Author Share Posted September 23, 2017 My system cost under £12 and was simple to fit and works perfect. Quote Link to comment Share on other sites More sharing options...
MJNewton Posted September 23, 2017 Share Posted September 23, 2017 I've been doing a bit of experimenting myself with seeing if there any alternative warning messages that could be triggered. In particular, I figured that if an overheat situation can be simulated then that ought to trigger a very alarming overheat warning on the centre console screen that even my wife would be sufficiently coerced into doing something about (immediately, not just casually mentioning it over dinner that evening!). So, I measured the response curve of the engine coolant temperature sensor and calculated what resistance would result in overheated temperatures being detected. Such a resistance could then be created by shunting in another resistor in parallel with the ECT sensor when the coolant bottle is detected as empty. A 1K ohm parallel resistance with the 2.8K ohm ECT value (at 90c) is equivalent to a simulated 115c (125c at 110c real) but having tried this it resulted in nothing more than the coolant gauge going to max and a rather subtle overheat warning symbol (the classic 'thermometer in the sea' type) on the instrument panel and nothing on the in-dash screen. Using Forscan I could see that my calculated temperature was spot on, and also that the appropriate DTCs were being triggered. So I then tried 680 ohms to represent more towards 150c and still nothing more. The anti-climax lowered my enthusiasm and so I didn't try for any higher. On a more positive note the fake overheat scenario does result in the cooling fan being set to max and thus in the case of coolant loss you would at least have that bonus whilst you tried to pull over but I can't imagine it saving the day, and the visual warning isn't anywhere near as in-your-face (like the low brake fluid message) to warrant this approach in my view. All in all a rather disappointing result. I am wondering if perhaps there isn't anything more warning wise for overheat temperatures, at least on those engines like mine that pre-date the introduction of a cylinder head temperature sensor which quite possibly does result in something more substantial. It could well be that I didn't go high enough with my fake temperatures but I would expect (hope) that 150c ought to be high enough! Also, whilst the engine was running I wasn't actually driving so perhaps the response might've been different if I had been moving along but I doubt it. Quote Link to comment Share on other sites More sharing options...
540itouring Posted September 23, 2017 Author Share Posted September 23, 2017 Yes I wend down that road first with my testing but the red temp light was very poor warning system and no sound warnings. I also fount that the temp warning had a big delay when adding and removing resistors which was not the best of warnings. The low brake fluid warning I found was easy to connect up and gave the best warning for what options were available with the standard parts of the car fitted from new. Quote Link to comment Share on other sites More sharing options...
MJNewton Posted September 23, 2017 Share Posted September 23, 2017 I must admit I was rather surprised by the subtlety of it. I thought I'd seen a 'Engine overheating - pull over now' warning on a photo of the centre dash info screen but I'm wondering if I'd been thinking about it so much I've just imagined it!! Reading back through the thread I see that you mention a ~10s delay before the low brake fluid warning appears. Does it not concern you that this might be too long a window to be unaware what's happened? I honestly don't know how long we've actually got before coolant loss results in catastrophe but I can't help but feel that every second might count. With this in mind I think I'm going to wire mine in parallel with the bonnet switch as that alert is instantaneous (and still passes the wife test in terms of being suitably alarming to warrant stopping[1]!). [1] I hope my wife never reads these posts - I'm hardly painting her in a good light! ;-) Quote Link to comment Share on other sites More sharing options...
540itouring Posted September 23, 2017 Author Share Posted September 23, 2017 36 minutes ago, MJNewton said: Reading back through the thread I see that you mention a ~10s delay before the low brake fluid warning appears. Does it not concern you that this might be too long a window to be unaware what's happened? I am sure the built in 10 second delay will not be a problem as 1 (this will prevent false alarms due to car going up a steep hill) & 2 ( the sensor is monitoring the expansion tank level which is high up so the alarm will trip 10 seconds after about 25 / 30mm coolant level drop so the engine will still have water when alarm sounds ). The 10 seconds delay may be less as only estimated this as I was testing on my own. I also connected the sensor to a constant +12 volt supply as the sensor only takes about 2mA draw Does the bonnet switch warn instantly ? I have only seen the bonnet display with the bonnet open so not tested that but I like the brake warning I have used as it gives dash brake light , front monitor display + warning sounds . That is three warnings at the same time so if that does not work I will be very surprised ! 1 Quote Link to comment Share on other sites More sharing options...
MJNewton Posted September 24, 2017 Share Posted September 24, 2017 It's a good point about the possible benefits of a damped trigger to avoid false alarms. I had assumed though that the expansion tank is heavily baffled to stop the coolant moving around and risking air being sucked in. You've probably done more testing than I though? Regards power there is a switched hot-at-on feed available from the upstream side of the reverse switch. It sits on a 7.5A fuse with nothing else attached (apart from the downstream reverse light of course). Quote Link to comment Share on other sites More sharing options...
540itouring Posted September 24, 2017 Author Share Posted September 24, 2017 1 hour ago, MJNewton said: Regards power there is a switched hot-at-on feed available from the upstream side of the reverse switch. It sits on a 7.5A fuse with nothing else attached (apart from the downstream reverse light of course). I run a cable from the engine bay fuse box across the loom at the rear of engine bay via a 1 amp fuse in a spare fuse location. I run the extra power cables when I converted the alarm system to a ST Cat 1 alarm. The fuse only feeds the sensor and the relay and is also easy to check all is well as with the bonnet up as you can see a dim glow from the led on the sensor. I tested my system and tilted the coolant tank while lifted off its mountings and is easy to do. 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted November 19, 2017 Share Posted November 19, 2017 Last week I did some testing and programming on the CANbus controlled coolant level warning system I have developed for my Focus MK3. On my testing setup I use a CANbus simulator (that I made). This CANbus simulator simulates the Focus MK3 CANbus system and puts the Focus MK3 CANbus messages onto the network. The CANbus simulator controls a spare instrument cluster I have. This way I am able to perform all testing and programming on my kitchen table. After the CANbus simulator was fully functional and I reverse engineered all relevant CANbus messages I developed a 12 Volt battery powered CANbus module that is based on an Arduino Nano and two MCP2515 CANbus controllers. My module is integrated into the existing CANbus network. My module is installed between the original CANbus wiring and basically splits the original CANbus network into CAN 0 and CAN 1. . (The word tellerunit in the schematic = Dutch for Instrument Cluster). A contactless coolant level switch is connected to my module. Based on the input signal of the coolant level switch my module controls the instrument cluster: If the coolant level is normal my module is in CANbus repeater/extender mode. In this mode it transfers all CANbus traffic from CAN 0 directly to CAN 1 and vice versa. This way the CANbus system works exactly the same as it was originally. If the coolant level is low after a few second delay my module switches from CANbus repeater/extender mode to CANbus filter mode. In this mode it transfers all CANbus traffic from CAN 0 directly to CAN 1 and vice versa except from the CANbus messages with ID 0x250 and ID 0x2A0. These CANbus messages are replaced by custom messages to activate a warning message and the engine warning light. During testing I decided to use the engine warning light and the warning message. In the future I may change this to a different warning light/message and control the temperature gauge to 120 degrees celsius. However to do this i only have to make some small software changes. After several hours of testing my system has proven to work perfectly. Last week I redesigned the circuit board layout of my module to reduce the size of the circuit board. Now I only need to install the circuit board inside a casing and cast it in resin before it is finished for installation. My module is currently based on the Focus MK3/MK3.5 MS CANbus (125 Kbps) instrument cluster. However after changing the software it can basically be used for every CANbus controlled MS CANbus (125 Kbps) or HS CANbus (500 Kbps) instrument cluster. You only have to reverse engineer the CANbus messages. 1 Quote Link to comment Share on other sites More sharing options...
Jeipii Posted February 10, 2018 Share Posted February 10, 2018 Damn, this feels too complicated for me to do. I would like to have some safety system for my 2014 Fiesta. Maybe installing a contactless sensor and some kind of small battery pack and buzzer set up inside the car (glove box for example) would do the job? Quote Link to comment Share on other sites More sharing options...
540itouring Posted February 10, 2018 Author Share Posted February 10, 2018 On 11/19/2017 at 10:46 AM, JW1982 said: Last week I did some testing and programming on the CANbus controlled coolant level warning system I have developed for my Focus MK3. On my testing setup I use a CANbus simulator (that I made). This CANbus simulator simulates the Focus MK3 CANbus system and puts the Focus MK3 CANbus messages onto the network. The CANbus simulator controls a spare instrument cluster I have. This way I am able to perform all testing and programming on my kitchen table. After the CANbus simulator was fully functional and I reverse engineered all relevant CANbus messages I developed a 12 Volt battery powered CANbus module that is based on an Arduino Nano and two MCP2515 CANbus controllers. My module is integrated into the existing CANbus network. My module is installed between the original CANbus wiring and basically splits the original CANbus network into CAN 0 and CAN 1. . (The word tellerunit in the schematic = Dutch for Instrument Cluster). A contactless coolant level switch is connected to my module. Based on the input signal of the coolant level switch my module controls the instrument cluster: If the coolant level is normal my module is in CANbus repeater/extender mode. In this mode it transfers all CANbus traffic from CAN 0 directly to CAN 1 and vice versa. This way the CANbus system works exactly the same as it was originally. If the coolant level is low after a few second delay my module switches from CANbus repeater/extender mode to CANbus filter mode. In this mode it transfers all CANbus traffic from CAN 0 directly to CAN 1 and vice versa except from the CANbus messages with ID 0x250 and ID 0x2A0. These CANbus messages are replaced by custom messages to activate a warning message and the engine warning light. During testing I decided to use the engine warning light and the warning message. In the future I may change this to a different warning light/message and control the temperature gauge to 120 degrees celsius. However to do this i only have to make some small software changes. After several hours of testing my system has proven to work perfectly. Last week I redesigned the circuit board layout of my module to reduce the size of the circuit board. Now I only need to install the circuit board inside a casing and cast it in resin before it is finished for installation. My module is currently based on the Focus MK3/MK3.5 MS CANbus (125 Kbps) instrument cluster. However after changing the software it can basically be used for every CANbus controlled MS CANbus (125 Kbps) or HS CANbus (500 Kbps) instrument cluster. You only have to reverse engineer the CANbus messages. Very good work but I think my system has proved a perfect solution for the coolant low warning and has now been working for months with no problems. , Your system will have other options for more complex projects but for this coolant warning topic is too complex for what is required. well done for your can bus hacking ! 1 Quote Link to comment Share on other sites More sharing options...
Jeipii Posted March 10, 2018 Share Posted March 10, 2018 Could one use an OBD scanner with display permanently set up in the car and some alarm set up in the display when engine temp goes over the normal limit? (the limit could be obtained by just normal driving and checking out how the engine temp behaves). Does the OBD-port give more accurate engine temp reading than the Fiesta mk7 and 7.5 pseudo engine temp gauge that is almost always showing "normal" temp even if the temp is varying a bit? Or is the problem with the inaccurate or laggy engine temp sensor? Also where is the Fiesta coolant temp sensor located? Is it under the coolant reservoir or somewhere inside the engine? Couldn't find it when I tried to look for it briefly. Quote Link to comment Share on other sites More sharing options...
