spitfire123
Omex rev limiter problems.
13 posts in this topic
hi all,
bought an aftermarket rev limiter for the fiesta and it came today and i fitted it.
the syestem works by going off the 3 wires that come out of the coil (T them)pack and the unit uses it own earth to make it hit the limiter harder faster...and is fully ajustable.
now scince this limiter has been on the engine dosent like idoling and keeps tryimg to die and between 2-4k is VERY violent and jerky?
now its a rev limiter surly it shoudlent effect the management system as it only 'piggy backs; it as such?
any advise is much apriciated.
car is a mk4 z-tecs 1.25.
cheers
how does it make the engine hit the limiter harder and faster??!?!
Is it supposed to make the engine rev faster??
I don't get the purpose of it?!?!?!?! :huh:
or the idea of one on a standard 1.25!! :lol:
but could you explain it a little more then I may be able to help!
How much did it cost and where from???
its basicly a aftermarket unit that you T of the limiter wires from the coil pack and the unit ha sits own earth and can be ajusted how hard the car can hit the limiter.
got it off ebay off a bloke for 55 there about 150 usaly.
cheers
im with piggy on this, i dont see how it can affect the rev limit etc if its only T'd off the wires to the coil.
sounds to me like it could do more damage than what its worth.
Ebay! ha, coulda put money on that! :lol:
To be honest...sounds like a loud of doush that you been told....
How is it meant to hit the limiter harder?!?!?!?! :huh:
It may be able to increase the limiter....but the ECU will hold back fuel also, so that won't do much.
And the only realy way to hit the limiter 'harder' would be to rev faster/harder...and that aint gonna be done by a piggy back earth chip thingy!
take it out, send it back, get money back!
Do you by any chance have a link to the ebay page?
ok, done loada research on this limiter....so Spitfire you owe me!!!
We need to know first if you have a four wire or three wire Omex Clubman rev limiter??
You need the 4 wire.
Also, this little box is designed to work INSTEAD of your standard limiter as its designed for modified vehicles....bot just a car with a back box and KnN, I mean rally cars and track cars!
It is used when the ECU limiter is not good enough and has been disconnected or removed.
Otherwise it will do sod all.
or as in your case when not fitted correctly, mess about with the car coz the ECU is trying to fight it!!
Got to ask...did you know much about it before you spent 50 quid!?!
hi mate,
yea cheers,
its a 4 wire omex clubman.
fitted it for a laugh wanted it for the sound and it worked well- and seriosly it does work.
however the unit ha sbeen revomed completley and the car has the same symtoms?? misfireing through the rev range..ive been told that it could be the plug leads/coil pack
so i got both off a breaker off ebay as need the car for tuesday afternoon.
to give yo an idea this is a 1.3 endura engine with it on, and seems to work fine on it:
cheers
won't really do what its meant to....
and as you seem to have proved, it buggers ya HT system! :lol:
yeah, sounds like either coil or leads....how much did you pay on ebay?
They not that expensive, and with HT stuff, you can't be sure they are good 2nd hand.
I got same problem with a mates honda at the mo, coil pack replaced few months ago by mechanic (2nd hand) and I think its gone wrong again!
ah, thats a bugger.
i paid £55
the coil pack ive bought is off a braker and he assure sit was broke the other day and tested before it was broken for spares.
did your mate with his coil pack have the same problems/symtons as me?
cheers
ah, thats a bugger.
i paid £55
cheers
honda is much longer story....but if you have misfire, you need to start with, plugs, coil pack and leads.
For 55quid, could get you brand new coil and leads from me motor factors!
i see,
me motor factors?
i see,
me motor factors?
yeah, sorry, bit o bad england there...
my local motor factors...good lads there :)
hope you have gooden too!
right change dthe coil pack, leads and plugs and its still not right.
i unplugged the lambda sensor and unplugge dthe throttle body sensor and it runs EXACLY the same....which makes me wonder if it infact runninf a closed circit (limp home mode) a sit seems to be ignoring its sensors?
there is no engine light on the dash so i dont know for certain.
does the 97 acuturly have limp home mode?
but its all over the shop.
any ideas?
cheers
