Albert27 Posted June 9, 2017 Share Posted June 9, 2017 Hi folks, When i'm running a usb phone charger from the cigarette lighter it stays on after the ignition is turned off. I've nearly been caught out a couple of times and am going to run out of luck before too long and come back to a flat battery. Is there a way to get it to switch on and off with the ignition? Car is 2008 mk 2.5. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Albert27 Posted June 13, 2017 Author Share Posted June 13, 2017 Can anyone help with this? Quote Link to comment Share on other sites More sharing options...
Micro Posted June 16, 2017 Share Posted June 16, 2017 I have attached a relay to the bottom of the socket next to the handbrake, and run a wire to an ignition switched fuse-tap. Unfortunately the advice about finding other fuse locations does not seem to be accurate for the Mk 2.5 at least. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted June 16, 2017 Share Posted June 16, 2017 On 6/9/2017 at 4:17 PM, Albert27 said: Hi folks, When i'm running a usb phone charger from the cigarette lighter it stays on after the ignition is turned off. I've nearly been caught out a couple of times and am going to run out of luck before too long and come back to a flat battery. Is there a way to get it to switch on and off with the ignition? Car is 2008 mk 2.5. Thanks in advance. I'm not 100% sure on what I'm about to tell you; because I haven't bothered to check it out for myself but I did hear on here a few times about there being two locations in the passenger footwell fuse board which operate the 12v sockets. You should only have the fuse in either of the two, you shouldn't have a fuse in both of them. The purpose is supposed to be: If the fuse is in fuse location A for example; then the 12v sockets only become live when the key is in the ignition. And If the fuse is in fuse location B for example; then the 12v sockets stay live all of the time and until 1 hour after the car has been locked untouched. The boot socket (if fitted) stays live all of the time regardless. If you would like to fit a usb socket in the glovebox which becomes live along with the ignition see part of this guide: Guide Fitting Dual Camera DVR System Focus Mk2 & Mk2.5Click Here 1 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted June 17, 2017 Author Share Posted June 17, 2017 6 hours ago, Lenny said: I'm not 100% sure on what I'm about to tell you; because I haven't bothered to check it out for myself but I did hear on here a few times about there being two locations in the passenger footwell fuse board which operate the 12v sockets. You should only have the fuse in either of the two, you shouldn't have a fuse in both of them. The purpose is supposed to be: If the fuse is in fuse location A for example; then the 12v sockets only become live when the key is in the ignition. And If the fuse is in fuse location B for example; then the 12v sockets stay live all of the time and until 1 hour after the car has been locked untouched. The boot socket (if fitted) stays live all of the time regardless. If you would like to fit a usb socket in the glovebox which becomes live along with the ignition see part of this guide: Guide Fitting Dual Camera DVR System Focus Mk2 & Mk2.5Click Here Thanks Lenny, that's really helpful 1 Quote Link to comment Share on other sites More sharing options...
BOF Posted June 17, 2017 Share Posted June 17, 2017 On Friday June 09, 2017 at 4:17 PM, Albert27 said: Hi folks, When i'm running a usb phone charger from the cigarette lighter it stays on after the ignition is turned off. c've nearly been caught out a couple of times and am going to run out of luck before too long and come back to a flat battery. Is there a way to get it to switch on and off with the ignition? Car is 2008 mk 2.5. Thanks in advance. Is your vehicle battery really that bad? The cig lighter on stays on for ~20 mins after the ignition goes off. Quote Link to comment Share on other sites More sharing options...
Albert27 Posted June 18, 2017 Author Share Posted June 18, 2017 On 17/06/2017 at 7:46 AM, BOF said: Is your vehicle battery really that bad? The cig lighter on stays on for ~20 mins after the ignition goes off. No battery is only 18 months old. How long could you leave a charger in the 12v with engine off before you'd drain a good battery? I always thought it wouldn't take long hence why i wanted to get it to switch off with ignition....... Quote Link to comment Share on other sites More sharing options...
WallaceZS Posted June 19, 2017 Share Posted June 19, 2017 On 17/06/2017 at 7:46 AM, BOF said: Is your vehicle battery really that bad? The cig lighter on stays on for ~20 mins after the ignition goes off. I thought this to be the case, but both the 12v sockets ( centre console / armrest ) in my '09 ZS stay live all the time. I've left things plugged in overnight though and had no battery issues. 1 Quote Link to comment Share on other sites More sharing options...
Koolkuts1 Posted January 6, 2020 Share Posted January 6, 2020 I’ve wired a simple switch to mine which glows red when it’s on. This is simply because I like to run the cigarette lighter when the ignition is off like if I leave something to charge when the car is left and was relatively easy Quote Link to comment Share on other sites More sharing options...
StephenFord Posted January 6, 2020 Share Posted January 6, 2020 I too was stitched up with this ridiculous situation of having an accessory socket that was permanently live. I solved it by when getting some other work done to my car, getting a spark to install a separate socket that was connected to the ignition! 1 Quote Link to comment Share on other sites More sharing options...
AndyUK32 Posted December 6, 2023 Share Posted December 6, 2023 It can be changed withFORScan and a USB/OBD adapter. See photo below, where MY=the cars year (note, it changes around 2013). 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted December 6, 2023 Share Posted December 6, 2023 22 minutes ago, unofix said: That's interesting. I see the data above is for the North American Fusion (Mondeo). Have you tried this on your Focus to see if the codes are the same ? I know that 'DanMac85' is a bit of a software hacker and has published a number of mods, but they are usually vehicle specific and don't work across the whole of the Ford platform. Quote Link to comment Share on other sites More sharing options...
AndyUK32 Posted December 6, 2023 Share Posted December 6, 2023 Well I have checked mine (2016 ford focus 3.5 DSG), and can put it straight. My 12v power outlets come on when the drivers’ door is opened, and switch off after about 30minutes. I checked FORScan and it was exactly as programmed. Incidentally, I have a SYNC 2 touch and have successfully activated a reversing camera. As far as I know the “modules” are the same, just programmed differently for different countries. I have tried a few enhancements from the spreadsheet and they all seem to work even FORScan reads the information and lets you select what you want. Mine did not lock when the door wasn’t opened - it does now etc. Quote Link to comment Share on other sites More sharing options...
