Ringer
Airbag warning light
I spent a good few hours today cleaning my partners 57 plate Galaxy Ghia.
This meant I had to move the drivers seat full forward and backward to get at all the carpet etc.
I noticed a small white (with red painted face) multiway connector loose underneath the front of the seat, on the right hand side (if facing forwards) of the underseat pull out tray.
But I can't find anywhere obvious where this should connect to.
But now the airbag light comes on with the ignition and stays on so clearly I have disturbed something.
Any help or guidance gratefully accepted.
Please accept my apologies if this is covered elsewhere in the forum and gently point me in that direction.
Hi Ringer,
I had a look on my car (2007 Galaxy ghia). Looking at the right-hand seat from the front there is a black wiring connector block to the left of the pull-out draw. The loom comes through the carpet and connects to that block which is secured with a 7mm screw.  Hope this helps.
Thanks OB. I'll check later today when I can get to the car.
The large black wiring connector was the culprit it seems.
Removed that, by undoing the retaining screw, applied WD40, reconnected it, all good.
Only 3 segments within the black connector are in use.
The extra connector I was concerned about comes through from the floor loom and appears to be ready to connect to the seat for other (not fitted) options I assume.
Thanks for the ideas.
